Based on the Virgin Oil Analysis data I have read on BITOG, SM oils have less ZDDP or referred here as zinc.
The negative effect is if you are breaking in a new engine which is not using the roller follower on the valvetrain, premature wear may result. That is why some are using ZDDP and moly additives on this condition. Otherwise, SM oil is good to use.
