[QUOTE=paetechie;1786115]anyone knows how to adjust the TPS
I know its location, connected to the TB...normal position is at 11% (i have my own OBD II scanner, that's why)
linis ko sana throttle body...can see black gum there but I might
need to re-adjust the TPS...read many forums the TPS needs re-adjustment due to high rpm problem after cleaning TB
vios 1.5g matic 2006
thanks[kailangan mo ng multi tester to check the resistan ng TPS at Voltage ng TPS mo.pacheck mo sa marunong mag check ng voltage at resistan yang TPS mo baka masyadong mataas na voltage nyan pag naka minor,.kailangan 1 volts lang ang reading nyan pag naka minor]
