Results 1 to 4 of 4
- Apr 2008
- 51
July 14th, 2011 11:59 AM #1anyone knows how to adjust the TPS
I know its location, connected to the TB...normal position is at 11% (i have my own OBD II scanner, that's why)
linis ko sana throttle body...can see black gum there but I might
need to re-adjust the TPS...read many forums the TPS needs re-adjustment due to high rpm problem after cleaning TB
vios 1.5g matic 2006
thanks
- May 2011
- 481
July 16th, 2011 10:00 AM #2most TPSs today don't have elongated mounting holes that you can reposition to "calibrate" the resistance in relation to the throttle position. they now have round holes and can only be installed in one position. these newer TPSs are recalibrated by the PCM. it recons itself everytime your PCM boots up just like your PC. this is a block learn capability built into the program.
- Apr 2011
- 11
July 18th, 2011 07:50 AM #3[QUOTE=paetechie;1786115]anyone knows how to adjust the TPS
thanks[kailangan mo ng multi tester to check the resistan ng TPS at Voltage ng TPS mo.pacheck mo sa marunong mag check ng voltage at resistan yang TPS mo baka masyadong mataas na voltage nyan pag naka minor,.kailangan 1 volts lang ang reading nyan pag naka minor]
- Apr 2008
- 51
July 20th, 2011 05:48 PM #4thanks for the reply, already cleaned my throttle body and MAF sensor last week. Idle RPM indeed went high after cleaning and sometimes hunts but stabilized after a few days. Now it's ok. TPS used to be 11% pre-cleaning (using my OBD), now it's 12.5%. RPM back to 700+ level at idle and improved car response
I'm now monitoring fuel consumption. It used to be almost 11kms/liter city driving (QC to Makati).
Daming issue ng SU7:grin:
Xiaomi E-Car
