Results 1 to 7 of 7
November 7th, 2008 08:22 AM #1
Hello,
can you help me with my problem. when i start the engine of my prado i notice a knock sound in the engine. 10 seconds after the engine started the noise disappear. do you have any idea as to what is the problem with the engine. 1998 Toyota Prado (commercial). ODO meter reading is 97,000, Engine 1KZ-T 3.0 Diesel. Thank you and more power..
THE AUTO SPECIALIST
- Mar 2006
- 607
November 7th, 2008 08:36 AM #2you might as well try to visit a shop specialized with diesel engines
to avoid guessing
that could be from fuel injection knock or the engine itself
or it could be somehing else
November 7th, 2008 10:09 AM #3
normal lang yan sir sa diesel fuel knock dalhin nyo po sa calibration to clean the nozzle,takataktatak ata ang sound nyan
- Sep 2006
- 1,335
November 8th, 2008 01:01 AM #4A faulty injector will continuously and/or intermittently knock as long as the engine is running,....... fresh start or not,....... hot or cold. Knock won't go away in 10 seconds.
This seems to be an engine problem. I hope it's not though. Drain a cup of oil from the crankcase to check for presence of metal particles.
Good luck!!!
- Sep 2006
- 1,335
November 8th, 2008 01:04 AM #5A faulty injector will continuously and/or intermittently knock as long as the engine is running,....... fresh start or not,....... hot or cold. Knock won't go away in 10 seconds.
This seems to be an engine problem, bearing failure probably. I hope it's not though.
Good luck!!!
November 8th, 2008 10:06 AM #6
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 16th, 2008 12:04 PM #7it might not be from the engine, i've heard some knocking on other cars that come from the belt tensioner... if malambot na it can cause that sound. you may want to check that out.
Xiaomi E-Car
