Results 11 to 16 of 16
April 24th, 2004 06:40 AM #11
sensya na sir nakalimutan ko na yung rows ng radiator tagal na rin kasing nabenta yung jeep ko
and hindi ko rin sure kung clutch fan sya....di ko alam na may ganito...sorry po talaga
- 10,620
April 24th, 2004 09:35 AM #12according to cong obet, medyo problematic ang 2LT especially yung nasa PRADO/BUNDERA/Landcruiser ii
nasa cylinder head yata ang medyo may sayad, hindi ko masyado narinig in detail kasi sobrang dami ng 4x4s dun.
April 24th, 2004 10:49 AM #13
haha lols nakaka duling kasi mga 4x4s doon lols tutulo pati sipon sa grabeng setup :D
April 24th, 2004 11:53 AM #14
possible cause nun overheat mo are 2 things, first bka nakakabit pa yun THERMOSTAT sa water spout mo, 2nd if you already experienced overheat b4 even once there's enough reason to suspect that you blew your Cylinder Head Gaskets... Sakit ng Toyota yan, pero replacement lang naman gagawin mo... Had it b4 sa 2 toyotas ko. Nag overheat yun isa coz my driver 4got to return the radiator cap then yun na... every other day nag ooverheat. When i had it checked sa Mech ko, busted yun cyl head gasket. Pero matibay naman ang cyl heads ng toyota, they dont easily crack. Chek mo din radiator mo bka puro kalawang na, and at least 3 to 4 rows if possible yun. If you're using aircon dapat may auxillary fan installed also.
Tsikot Member Rank 4
- Feb 2004
- 1,704
April 24th, 2004 12:13 PM #15yung friend ko, nilagyan nya ng turbo ang 2L ng revo diesel nya. mabilis naman daw. problema, casa ang turbo nya, so over 100,000 pesos and bili nya. ouch
andy
- 170
April 25th, 2004 05:19 PM #16Problema nga 2L-T engine cylinder head, madali mag overheat tapos nabebengkong ang cylinder head. We had 3 cases na ganyan, from subic landcruisers and hi ace.
