Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
    #21
    Quote Originally Posted by 09959945532 View Post
    Mga sir pahelp naman. Nagoverheat kasi yun honda civic fd ko yr 2008 then pina overhaul ko sa bosch after ma overhaul. Break in ng 1000km. After ma break in binalik ko dun pra machange oil at retorque. Dahil kulang sa oras pinabalik ako sa ibang araw pra mare torque. Papunta nko sa bosch 120 kph speed ko at nun niretorque na milky yun oil sa engine at iniwan ko nalang dun. May iba pakong naririnig sa engine prang knocking sounds. Pahelp namn thank you
    and the oil wasn't latte before overhaul?
    sounds like naghahalo ang oil sa tubig...
    bad sign.
    see if it recurs after re-torque. i feel, it will.
    engine knocking sounds?
    could still be just ignition timing that needs adjustment.
    Oct 2017
    #22
    bad sign.
    Yes sir naghahalo po. After re-torque binalik ko ulit sa bosch kasi nangangamoy coolant yun sa loob ng car pagtingin ko ubus na pla coolant. Pinaayos ko ulit sa kanila sir. Ewan ko kng kailan matatapos yun.. cylinder head sir pag manipis naba kailangan naba palitan yun?
Top overhaul price (engine leak)
