Results 1 to 20 of 22
    Apr 2015
    Mga sir,
    Magkano po ba magpa top overhaul + rethread ng block?
    Sabi kasi kailangan na irethread yun block ko kasi loose na.
    Saka feeling ko may signs na ng blown up gasket.
    Quote Originally Posted by Renan Reora View Post
    Mga sir,
    around 15-20k, to be safe.... baka sobra na yan.
    Mga sir,
    Oct 2009
    anong makina ba..
    handa ka ng mga 25k siguradong matino na pang taas na makina mo dyan..baka may sukli kapang pang labor.sa mekaniko
    anong makina ba..
    Mga sir,
    Finalized kaagad na loose block kaya sabi sa iyo overhaul + irethread?
    Feeling mo may signs of blown head gasket?[emoji19]
    Sent from my UP+ using Tapatalk
    Apr 2015
    Yes sir. nasilip na ng mekaniko. Loose talaga yun thread. Ang ginawa sinalpakan na lang ng mas malaking turnilyo.
    Pero may leak pa din e. Saka nag bbrown na yun kulay ng tubig ko sa radiator.
    Hindi naman ako nag ooverheat pa kasi nakarekta na yun fan e.
    Kaya plano ko ipa overhaul na kung kailangan at ibalik yun thermostat and switch para zero na problema sa makina.
    Jul 2015
    Mga sir tanung lang po baguhan po kc anu pong result pag natop overhaul? Mawwla b ung usok? At mga sir anu anu po bng pinapaltan pag top overhaul?
    Quote Originally Posted by Jaytamz30 View Post
    A top overhaul only covers the replacement of components inside the cylinder head without removing the engine from the vehicle, such as valve and rocker arm replacement. It may or may not include a valve job. So possible mawala ang leak, pero depende kung nasaan ang leak..... Yes, mawawala ang usok.... And the results, power on the engine as well as engine compression can be restored.
    A loose thread can also be caused by a warped block/head or engine overheating. Do a compression test also to ensure what exactly may be wrong, and have all screw holes rethreaded as chances are the other good threads may go loose soon (this happened to me).
    OT: No textspeak please. It's really painful to read
    Jul 2015
    Salamat po 1D4LV sa info malaking tulong at dagdag kaalaman po yang cnabi nyo
    Jul 2015
    Mga sir tanung lang po kakatapos lang po matop overahul ung car ko pero po kada start po may puting usok n lumalabs kada start anu po kayang problema at paanu po kaya matanggal ang usok?
    depende yan..... malakas ba ang usok? tuwing start lang ba? di ba malamig ang panahon? baka water vapor lang.
    white smoke is water.....dark smoke is oil.
    Jan 2011
    white smoke is likely a problem on the valve seals. kaso sabi mo bagong top overhaul.. na grind ba ang valves?
    Jul 2015
    can anyone recommend a shop/casa that offers top/general overhaul service with reasonable price po? Thanks.
    Mar 2015
    Quote Originally Posted by konichiwa888 View Post
    May shop po sa may p.tuazon cubao near Lto or house service pls.contact Domeng (0916) 331 7722 to make schedule. Hope this helps sir.
    Jul 2017
    Mga sir gandang hapon po! Sorry po newbie lng po pagdating sa sasakyan. I am driving a mazda 3 2004 model. Tanong lang po if may idea po kayo kung mgkano po mgpa top overhaul and san po kya may maaus na talyer at idea po kung magkano abutin? Recently po kasi nag overheat ung sasakyan ko and kala ko po dala lang ng leak sa water overflow reservoir which napalitan ko na po ngaun ng bago but still unti unti pa rin po nauubos ung tubig sa reservoir. Tapos po knina pag check ko po sa oil dipstick at engine oil cap may sludge po na prang kulay gatas po. Sabi po ng friend ko bka may tama na daw head gasket ko. Sana po matulungan nyo ko. Mejo tight din na po kasi budget ko.
    Ask na rin po sana ako if safe pa po ba idrive ito? Right now po ngsstart na po ako mgipon ng pera dahil ang sabi po sa akin maghanda na daw ako ng budget at mahal daw po mgpa top overhaul... please po tulungan nyo po ako.... salamat po
    Oct 2017
    Yun car ko din may white na usok na parang may lumalabas na tubig. Bagong overhaul din.
    Quote Originally Posted by 09959945532 View Post
    pag bagong start from cold, this could be normal.
    Jun 2008
    Quote Originally Posted by rcdgreat View Post
    Hindi safe patakbuhin ang makina. Check/pressure test ang oil cooler b4 galawin ang cylinder head. Kung good ang oil cooler pwede mag proceed sa cylinder head (top overhaul), head gasket usually ang leaking assuming na walang crack.
    Sent from my NX549J using Tsikot Forums mobile app
    Oct 2017
    Mga sir pahelp naman. Nagoverheat kasi yun honda civic fd ko yr 2008 then pina overhaul ko sa bosch after ma overhaul. Break in ng 1000km. After ma break in binalik ko dun pra machange oil at retorque. Dahil kulang sa oras pinabalik ako sa ibang araw pra mare torque. Papunta nko sa bosch 120 kph speed ko at nun niretorque na milky yun oil sa engine at iniwan ko nalang dun. May iba pakong naririnig sa engine prang knocking sounds. Pahelp namn thank you
    and the oil wasn't latte before overhaul?
    sounds like naghahalo ang oil sa tubig...
    bad sign.
    see if it recurs after re-torque. i feel, it will.
    engine knocking sounds?
    could still be just ignition timing that needs adjustment.
Top overhaul price (engine leak)
