Mga sir pahelp naman. Nagoverheat kasi yun honda civic fd ko yr 2008 then pina overhaul ko sa bosch after ma overhaul. Break in ng 1000km. After ma break in binalik ko dun pra machange oil at retorque. Dahil kulang sa oras pinabalik ako sa ibang araw pra mare torque. Papunta nko sa bosch 120 kph speed ko at nun niretorque na milky yun oil sa engine at iniwan ko nalang dun. May iba pakong naririnig sa engine prang knocking sounds. Pahelp namn thank you
and the oil wasn't latte before overhaul?
sounds like naghahalo ang oil sa tubig...
bad sign.
see if it recurs after re-torque. i feel, it will.
engine knocking sounds?
could still be just ignition timing that needs adjustment.
bad sign.
Yes sir naghahalo po. After re-torque binalik ko ulit sa bosch kasi nangangamoy coolant yun sa loob ng car pagtingin ko ubus na pla coolant. Pinaayos ko ulit sa kanila sir. Ewan ko kng kailan matatapos yun.. cylinder head sir pag manipis naba kailangan naba palitan yun?
It should be repairable. The labels on the tire sealant all say that its a temporary fix and you...
Liquid tire sealant
