Results 1 to 10 of 22
- Apr 2015
- 28
July 10th, 2015 05:00 PM #1Mga sir,
Magkano po ba magpa top overhaul + rethread ng block?
Sabi kasi kailangan na irethread yun block ko kasi loose na.
Saka feeling ko may signs na ng blown up gasket.
July 10th, 2015 05:07 PM #2
- Oct 2009
- 2,271
July 10th, 2015 05:53 PM #3anong makina ba..
handa ka ng mga 25k siguradong matino na pang taas na makina mo dyan..baka may sukli kapang pang labor.sa mekaniko
anong makina ba..
- Mar 2014
- 901
July 10th, 2015 10:16 PM #4
- Apr 2015
- 28
July 13th, 2015 10:44 AM #5Yes sir. nasilip na ng mekaniko. Loose talaga yun thread. Ang ginawa sinalpakan na lang ng mas malaking turnilyo.
Pero may leak pa din e. Saka nag bbrown na yun kulay ng tubig ko sa radiator.
Hindi naman ako nag ooverheat pa kasi nakarekta na yun fan e.
Kaya plano ko ipa overhaul na kung kailangan at ibalik yun thermostat and switch para zero na problema sa makina.
- Jul 2015
- 9
July 19th, 2015 01:37 AM #6Mga sir tanung lang po baguhan po kc anu pong result pag natop overhaul? Mawwla b ung usok? At mga sir anu anu po bng pinapaltan pag top overhaul?
July 21st, 2015 04:53 PM #7
A top overhaul only covers the replacement of components inside the cylinder head without removing the engine from the vehicle, such as valve and rocker arm replacement. It may or may not include a valve job. So possible mawala ang leak, pero depende kung nasaan ang leak..... Yes, mawawala ang usok.... And the results, power on the engine as well as engine compression can be restored.
July 21st, 2015 06:58 PM #8
A loose thread can also be caused by a warped block/head or engine overheating. Do a compression test also to ensure what exactly may be wrong, and have all screw holes rethreaded as chances are the other good threads may go loose soon (this happened to me).
OT: No textspeak please. It's really painful to read
- Jul 2015
- 9
July 21st, 2015 10:24 PM #9Salamat po 1D4LV sa info malaking tulong at dagdag kaalaman po yang cnabi nyo
- Jul 2015
- 9
July 23rd, 2015 01:19 PM #10Mga sir tanung lang po kakatapos lang po matop overahul ung car ko pero po kada start po may puting usok n lumalabs kada start anu po kayang problema at paanu po kaya matanggal ang usok?
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
