Quote Originally Posted by sirkosero View Post
mababa ang reading. pantay pantay naman but still some work needs to be done.
sana nasubukan mo mag wet compression test din. its done by putting a few drops of oil sa spark plug hole then cranking the engine for the compression test.
kung gumanda results, be prepared for an overhaul since piston rings are worn out.
kung no change sa reading, you would have to do top overhaul only.
Thanks bro. Will bring it back for wet compression check. But just assuming i would need top overhaul only. Based on the "dry"compression results i got, how soon should I have the top overhaul done?
