Well the 2004 STP oil treatment have a ZDDP Zinc of 1,959. But hey you can find a STP with 2004 manufactured in any auto supplies.
STP 2004
Calcium 1371 ppm
Phosphorus 1814
Zinc 1959
100C viscosity 108 cSt.
STP 2004
Calcium 1371 ppm
Phosphorus 1814
Zinc 1959
Plenty of it in the states at a place called big lots, I just had some analized but it came back kinda low, it actually should be around 3900ppm zinc for the Red STP 4cly oil treatment. I did not mix up the sample and took the oil from the top so I think it settle out since it has been sitting in a warehouse for about 8 years. But it's still perfectly fine, I'm going to get anouther sample run. It should be adding around 400ppm zinc and phos to 5 quarts of oils. The STP oil treatment in the blue bottle has half as much as the red due to EPA rules on ZDDP content and it's also much thicker.
STP - Bob Is The Oil Guy
I use it in my cars to boost up my oil, and get a little bump in fuel economy with it. I only use a additive is I know exactly what is in it. I posted in the oil filter thread about where to do engine oil testing. Maybe someone can get the stuff tested to see if it's worth the money. It's pretty much why I have not said anything good nor bad about it. Have no ideal what's in it.
http://www.top1oil.com/pds/10108_PDS.pdf
Wonder just how much moly this stuff has in it? What's the cost of this stuff anyways.
So far, na try ko pa lang na additive is Liquiy moly... the MoS2 and the ceratec...
The MoS2 which has lots of moly in it did improve my fuel consumption from 4-5 to 5-6 on a 6 cylinder gasoline engine.
while the ceratec which has lots of boron performed just the same from 10-11 to 11-12 on a 4 cylinder diesel engine.
i think before you use any additive it must have proper documentation and technical specs in the first place so you can benchmark it...
Fasten your seatbelt! Or else...Driven To Thrill!
Anu pu ba ung engine (fuel) treatment sorry kinda new in this section just got my 1st car about a month ago.
fuel treatment hinahalo sa fuel
engine and oil treatment hinahalo sa engine oil
There regular engine treatment is just a viscosity modifier, No zinc or other anti friction additives, If your already using a good 40 weight oil there really is no need to use it. Now there green oil additive has moly and probably worth a look.
The MoS2 is a pretty solid additive, some oils have that level of moly in it, well pretty close like Motul 300v.
enkendel user 1200 isang bote 40k na walang change oil adventure pang biyahe https://www.youtube.com/watch?v=iKdkLVE6KS0
sir/mam san po kaya dito mas maganda sa dalawa top 1 engine treatment
http://www.top1oil.com/USA/products/...rge/eotcan.png
Other Products | Engine Oil Treatment Gold
and
http://www.top1oil.com/USA/products/...opgreencan.png
Other Products| Green Super Oil Treatment
