Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 59
    Dec 2009
    #21
    yeah bigyan nyo na sample... gusto libre eh
    Dec 2010
    #22
    Quote Originally Posted by drich_enriquez View Post
    Good Day,
    Ask ko lang kung ok itong Top 1 Engine Treatment? Balak ko ilagay sa Toyota Innova J Gas. I appreciate your comment and baka may ibang brand na alam mo bukod sa nabanggit ko brand ng Engine additive. Thanks in advanced.
    good day sir..
    sir try ninyo po yung AERO WONDER LUBE (ENGINE TREATMENT) ok po siya sir dami po benifits sa sasakyan.. maganda po subok na subok na po siya...pinoy po ang naka imbento ng products... thanks godbless....mabuhay ang pinoy...
    #23
    engine treatment? yung mga products na sinasabi i-co-coat daw ang loob ng engine with some kind of slippery substance para less friction... sayang pera
    basta mag change oil ka lang sa tamang interval ok na
    yes tapos naka lagay sa lata quieter engine noise and improves fuel economy.
    #24
    Quote Originally Posted by philipdavid17 View Post
    good evening....
    mga frendship try ninyo po ang AERO WONDER LUBE (ENGINE TREATMENT) maganda po siya dami po siya benifits sa sasakyan.. subok na subok na po itong product na ito... Thanks po Godbless...
    Sir Thank you sa Info mo, It really helps ito advisemo. Ummm... Ask ko lang, saan kaya meron yan? Kasi sa concorde, DIY, Ace, etc wla sila. hehe
    #25
    [QUOTE=Retz;1860166]
    sir oil ito.
    #26
    Quote Originally Posted by miko101130 View Post
    from personal experience sa dami na din an try ko na fuel and oil additives, i think you should try or do your own personal research on this product, it name is liqui moly.. search mo sa net... german made siya, medyo mahal nga din but proven to do what it claims...
    Liqui moly......... I heard that product na nabasa ko sa newspaper sa motoring section ng Phil. Star. Dami nag sasabi ok yan. The question is.... saan meron yan? Sa Blade, Concorde, DIY, Ace etc. wala sila.
    #27
    good day sir..
    Thank you sa info mo, I appreciate your help. Um.... Ito ang tanong ko, saan kaya meron yun sinasabi mong AERO WONDER Lube? Sa Concorde wala yan.
    #28
    kung sa engine treatment ok daw talaga yun liquimoly ceratec. 800 lang dati. ewan ko na ngayon. gusto ko sana palagyan yun subbie ko pero sabi nun tindero di pa daw kailangan pagbago pa yun sasakyan. mas ok daw sa high mileage vehicles. madami daw kumukuha sa kanila ng mga luma na mini cooper and ok daw ang feedback. sa fusion r dati meron dyan sa may e.rod malapit sa happy sauna
    #29
    Wala yung mga claims dyan sa AERO WONDER LUBE sa claims ng GTOil....
    see the following sites: The Green Technology Oil
    ito pa ang nasa FAQ nila: Green Technology FAQ: No More Oil Change?
    marami na silang "Centers" dito sa Pilipinas: OTG_KARIS
    so meron pa ba kayong mas outrageous claims na mas mahigit pa kesa GTOil????hehehe
    Quote Originally Posted by attyallanlatras View Post
    Binasa ko yan, puro BS!!!!
    #31
    STP oil treatment is the best product out there, (providing you use it correctly) It is not intended to be used for oil burning engines as a quick fix or any other quick fix ideas. You put a bottle of it in your engine every time you change your oil.
    STP is still average $2.50 - $3.00 a bottle, depending on where you get it and it does the same thing that all these higher priced additives claim to do. I use it, and have been for over 20 years. It contains detergents which enhances the oil's viscosity and keeps the engine clean and sludge free, and when used regularly over a period of time, it will actually "bake" into the metal inside the engine leaving a protective film to reduce wear. It is ok to use it in a new car after the break in period has passed, that will be a sure guarantee that your engine will have a long life providing you change oil regularly. I have worked on engines that has used it and personally seen the positive effects it has. I have not seen anything that outdoes it, and besides, take a moment and think about how long that product has been on the market......................... a long time.
    why can't people just be satisfied with MOTOR OIL?
    motor oil na recommended ng car manufacturer
    yun lang
    baket kailangan pa ng whatever treatment treatment?
    Quote Originally Posted by EE100shiro View Post
    our mechanics use STP pang alis blow-by
    old engines na kailangan na palitan ng piston ring... STP is a remedy... just to get the unit sold
    kaysa gagastos pa kami palit piston ring
    #34
    our 2NZ-FE vios uses STP every oil changed up to now 137,870km on odometer, engine power still the same, our corolla 2E with 494,160 km uses STP since 1995 till now 2 times overhaul conrod bearing, main bearing, camshaft ,crankshaft, rocker arm, engine block, etc. are still original 1995, only piston ring replaced.
    Jun 2011
    #35
    top one... ive tried that no changes at all... fc, temp. etc... mura lang pero sayang pa din ang pera....
    #36
    magkaiba ang engine oil treatment sa engine (fuel) treatment
    But they have common outcome.
    You treat the oil, it benefits the engine.
    You treat the fuel, it benefits the engine and deposits on intake valves and manifolds, carburetors and fuel injectors.
    These both can helps the engine.
    Jun 2008
    #37
    My own take:
    Don't use engine (oil) treatment sa brand new or newly overhauled engine. After break-in or about 15k odometer reading pwede na.
    I regularly used Pertua engine treatment from 1988 to 2003 in my old 1979 12R toyota corona wagon. The engine was running very smooth more than the nissan sentra of my neighbor. I scrapped the car not because of the bad engine but due to body defects.
    Quote Originally Posted by weisshorn View Post
    My own take:
    So Pertua is ok for you in your experience sir? Would you recommend it though? It is expensive pa naman.
    Dec 2011
    #39
    My own take:
    Don't use engine (oil) treatment sa brand new or newly overhauled engine...
    ..neither nor to an old car. Better use good oil instead.
    Using oil treatment might not have compatibility with your brand oil, unless it was tested for compatibility!
    #40
    inside of STP oil treatment 2010
    ZDDP (ZINC) is the one who makes the engine last forever protects against engine wear.
