yeah bigyan nyo na sample... gusto libre eh
kung sa engine treatment ok daw talaga yun liquimoly ceratec. 800 lang dati. ewan ko na ngayon. gusto ko sana palagyan yun subbie ko pero sabi nun tindero di pa daw kailangan pagbago pa yun sasakyan. mas ok daw sa high mileage vehicles. madami daw kumukuha sa kanila ng mga luma na mini cooper and ok daw ang feedback. sa fusion r dati meron dyan sa may e.rod malapit sa happy sauna
Wala yung mga claims dyan sa AERO WONDER LUBE sa claims ng GTOil....
see the following sites: The Green Technology Oil
ito pa ang nasa FAQ nila: Green Technology FAQ: No More Oil Change?
marami na silang "Centers" dito sa Pilipinas: OTG_KARIS
so meron pa ba kayong mas outrageous claims na mas mahigit pa kesa GTOil????hehehe
STP oil treatment is the best product out there, (providing you use it correctly) It is not intended to be used for oil burning engines as a quick fix or any other quick fix ideas. You put a bottle of it in your engine every time you change your oil.
STP is still average $2.50 - $3.00 a bottle, depending on where you get it and it does the same thing that all these higher priced additives claim to do. I use it, and have been for over 20 years. It contains detergents which enhances the oil's viscosity and keeps the engine clean and sludge free, and when used regularly over a period of time, it will actually "bake" into the metal inside the engine leaving a protective film to reduce wear. It is ok to use it in a new car after the break in period has passed, that will be a sure guarantee that your engine will have a long life providing you change oil regularly. I have worked on engines that has used it and personally seen the positive effects it has. I have not seen anything that outdoes it, and besides, take a moment and think about how long that product has been on the market......................... a long time.
why can't people just be satisfied with MOTOR OIL?
motor oil na recommended ng car manufacturer
yun lang
baket kailangan pa ng whatever treatment treatment?
our 2NZ-FE vios uses STP every oil changed up to now 137,870km on odometer, engine power still the same, our corolla 2E with 494,160 km uses STP since 1995 till now 2 times overhaul conrod bearing, main bearing, camshaft ,crankshaft, rocker arm, engine block, etc. are still original 1995, only piston ring replaced.
top one... ive tried that no changes at all... fc, temp. etc... mura lang pero sayang pa din ang pera....
My own take:
Don't use engine (oil) treatment sa brand new or newly overhauled engine. After break-in or about 15k odometer reading pwede na.
I regularly used Pertua engine treatment from 1988 to 2003 in my old 1979 12R toyota corona wagon. The engine was running very smooth more than the nissan sentra of my neighbor. I scrapped the car not because of the bad engine but due to body defects.
inside of STP oil treatment 2010
ZDDP (ZINC) is the one who makes the engine last forever protects against engine wear.
