Results 1 to 10 of 23
- Aug 2008
- 11
August 20th, 2008 04:10 PM #1Hi Guys,
how often do we need to replace a timing belt? and how can we know that it needs to be replaced na?
maraming salamat po!
August 20th, 2008 08:22 PM #2
^^ manufacturers normally recommend on having it changed between the 70-80km mark. consider it as part of your preventive maintenance.
you can usually check for the condition of the belt via visual inspection, pero normally, people who are proactive do not do this, but follow the odo reading as i've stated above.
and yes. do not hold on and hesitate in changing this. more expensive pag naputulan ka.
- Sep 2007
- 215
August 26th, 2008 07:07 PM #3usually dapat mga 100km ... that is what the manufacture recommend ... pero dito sa philippines sa sobrang traffic this is not followed usually mga 80 - 90 km pinapalitan na ...
if your buying a second hand car it is best to replace it ... kasi pagnaputulan yan ... overhaul na ang baksak mo
regy
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 31st, 2008 03:16 PM #4replace it at 80. when in doubt kung napalitan na just replace it.
cheaper in the long run.
- Aug 2008
- 11
September 1st, 2008 09:38 AM #5thanks for all the advice, btw do you know where to buy original timing belt for a corolla? and do you guys have an idea how much? thanks po ulet
- Dec 2007
- 142
September 1st, 2008 10:11 AM #6
September 3rd, 2008 09:21 AM #7
September 3rd, 2008 01:21 PM #9
"thanks for all the advice, btw do you know where to buy original timing belt for a corolla? and do you guys have an idea how much? thanks po ulet"
To lhie : Kung wala na ang parts ng modelo ng corolla mo sa casa, for sure you won't be able to find original parts. You'll have to make do with replacement parts. Try mo sa Banawe o d kaya sa Paco. Baka sakali, meron pa duon.
"magkano aabutin nito lahat-lahat? mga estimate lang? "
To fLaKeZ: Kung kasama na labor, magla-an ka ng mga P8th - P10th. Depende pa sa singil ng mekaniko (usually P2,500.00)
September 4th, 2008 11:02 AM #10
Xiaomi E-Car
