Results 31 to 40 of 49
- Apr 2011
- 4
April 19th, 2011 09:13 PM #31Nalagutan na rin ako nito dati along c5 papuntang taguig. Traumatic talaga, pagkalagpas ng elevated u-turn, namatay makina. Ni-try ko i-start *ouch*! bawal pala kasi nadale yung valves. Ayun na-tow ako pauwi, laki ng nagastos. inoverhaul nila. hahaay! 2nd hand ko kasi nabili yung oto. Tas murang timing belt lang pala ang ikinabit. Ngayon mas conscious na ako, pinacheck ko na sya ulit recently sa trusted mechanic ko, malamang sa July magpalit na ulit ako. It's better safe than sorry...
April 20th, 2011 01:54 PM #32
April 21st, 2011 11:41 AM #33
we bought a 2nd hand prado 90 series model and make it a point to change the timing belt as soon as we got it from the previous owner. it is better to be safe. though my mechanic said it is still new and can run a thousand miles pa but my father opted to change it.
- Mar 2004
- 652
April 23rd, 2011 11:04 AM #34sir, just try to imagine kung magkano magiging bukol mo pag nalagutan ka ng belt, dale valves mo, luckily pag di nadamay ang piston rods mo.
to appease yourself from the unwanted expenses, isipin mo na lang na forward expenses mo ito, yung mga dapat gagastusin mo later on. So, in a sense makakatipid ka pa.
ang isang plus factor mo dito is that, di ja na kakabakaba na while driving, baka malagutan ka ng Tbelt. Lalo na kung mag long distance trip ka to the province, lalo na honda yan ride mo (di gaya ng toyota na sabi nila kahit sa botika makabili ka ng piyesa ).
Bottom line is, just enjoy driving your pipip (kaya lang ang presyo ng gaso. . ooouuuchhhh!!!)
April 23rd, 2011 03:15 PM #35
*TS, tama sila. maintenance naman kasi ang ginawa mo at di mo na inantay na masira. imagine mo na lang pag naabutan ka sa kalye isipin mo pa towing at kung saan papagawa. meron pa nga iba dyan na pinapagawa ng pansamantagal lalo lumaki gastos. ok na yan para meron kang fish of mind.
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 12th, 2011 07:24 AM #36maintenance is maintenance. feel bad if you replace a part that is not a wear item na hindi sira. pero pag wear item then it's better to replace it than to let it break on the road.
June 12th, 2011 08:14 AM #37
June 14th, 2011 07:38 PM #38
Must take note also on the installation of the t-belts also. these synchronous belts are made to rotate in 1 direction only. if you can read the belt markings when facing the engine, install is ok.
guys, take note also of the irregularity of the noise emitted and feel of the engine....last week lang I saw a broken balancer belt on a 4d56 advie. A gov't vehicle which is taken for granted. The driver and the mechanic came up to me to "borrow" some silicone sealant to cure a leaking valve cover. Upon removal of the timing cover, I saw something is amiss. The left balancer sprocket popped from its seat due to a broken bolt. Good thing, the cam belt is good. Good thing the advie and mine share the same engine except for the turbo, I supervised the removal and installation of belts and seals kahit na maraming miron na driver din na nakikialam with my knowledge na mali naman pinagsasabi.
Kapag may nararamdaman ako sa takbo at andar ng pipip ko eh lagi ko iniinspect yung tension ng timing belts as well as the teeth.
June 14th, 2011 08:37 PM #39Cost of parts :
timing belt - 1300
aircon and alternator belt - 700
camshaft and crankshaft seals - 500
tensioner bearing - 600
labor - 1800
June 19th, 2011 10:51 AM #40
Xiaomi E-Car
