Results 21 to 30 of 40
May 19th, 2018 06:38 PM #21
- Dec 2017
- 1,018
May 19th, 2018 06:45 PM #22They can always do a mod and install a hood vent. That would also look cool as well. LOL!
May 19th, 2018 07:40 PM #23
I see that you were referring to the radiant heat which I became confused. How about the coolant lost, can you explain how that happened?
I've read this thing but coolant lost wasn't mentioned:
Do I need to Change My Car Thermostat? | BlueDevil Products
May 21st, 2018 10:33 AM #24
6km/l before thermostat change
7.3+ after (no express way)
both 60+ liters (full tank method)
happy happy joy joy [emoji16]
FOCUSLast edited by StockEngine; May 21st, 2018 at 10:42 AM.
- Sep 2007
- 267
May 21st, 2018 10:44 AM #25^ Is this for your Elantra? What were the symptoms aside from the radiant heat and bad FC? Did the temp gauge rise above its normal level?
May 21st, 2018 11:06 AM #26
Bro stock, do use an obd scanner/reader?
It would've been interesting to compare the working temp of your cooling system pre & post thermostat change
May 22nd, 2018 12:56 PM #27
May 22nd, 2018 12:58 PM #28
- Sep 2007
- 267
May 22nd, 2018 01:08 PM #29elantra does 12+ after and 10+ before..That is seriously good FC for an Elantra! Is this the 1.6 Gamma or 1.8 nu engine? M/T or A/T? Average speed for that mileage?
Baka naman M/T pure highway driving yan running at 80 km/h? He he....
May 22nd, 2018 01:10 PM #30
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
