Results 1 to 10 of 11
- May 2007
- 101
February 7th, 2009 06:51 AM #1meron akong nabasang mga lumang thread about td27t na mahirap imaintain and better settle sa td27 na lang.
is this still true today? iniisip ko kasi na baka ganon noon pero ngayon di na
February 7th, 2009 10:19 AM #2
Ok naman TD27 I am assuming na yung may T is turbo.
Mahal lang magpaservice ng turbo pero kung laging ok ang engine oil linilinis ang filter at tama ang calibration then hindi ka bibigyan ng problema.
- Feb 2009
- 27
February 7th, 2009 10:27 AM #3haven't heard problems with TD27-T in terms of parts availability and maintenance. parts are pretty much the same with the non-turbo type except for the pistons and rings which are easy to get too. pero common naman sa mga turbo charged engines ang nagkakaproblema sa turbo charger, lalo na sa mga surplus engines. probably na worn out na nung dating may ari. pero d2 sa philippines common naman ang 2nd hand parts or chop-chop so you won't be having problems finding a replacement turbo charger assy.
February 7th, 2009 01:20 PM #4
There are no such a thing between that two engines are harder to maintain than the other. If you can do your regular maintenance on the engine, what makes you think the other are harder? Does this engine required a Master mechanic to look at it and need an special tools? If it is, then that's a problem.
- May 2007
- 101
February 11th, 2009 03:18 AM #5
February 11th, 2009 04:16 AM #6
February 11th, 2009 10:27 AM #7
One important advice. Find a Nissan diesel engine na hindi VP44 ang injection pump.
Tsikot Member Rank 3
- Nov 2002
- 1,762
February 11th, 2009 11:12 AM #8madali lang siguro ang parts and maintenance nyan. baka dati mahirap pero ngayon dami na kasing surplus terranos na pumasok dito with that engine. yung iba td27ti pa ata. dami na ring nagconvert na local td27 and added a turbo. same with engine swaps of z24 to td27t.
as what others said, main difference lang nya sa td27 is yung turbo. so engine parts, may mahahanap ka.
- Oct 2009
- 72
March 14th, 2010 09:28 AM #9Engines with turbo uses it engine oil to lubricate and cool the shaft of the turbo. With these additional burden on the engine oil, the engine oil change interval must be strictly followed.
nagapalit ako ng pang-ilalim kahapon so takbo ako magpa- alignment service maybe tomorrow. ...
Wheel Alignment
