How would you know kung sira yung :
A/T Temp Sensor ?
A/T Oil Cooler?
A/T itself over heating?
Happened to me on the way to Sagada after 8 hours continous drive. A/T lamp went on at the uphill part of Banawe (actually puro uphill na yon). Stopped for 20mins. then light was off again.
On the way home A/T lamp kept coming on and off. We had a 2 hour lunch and when i started the engine, the lamp was still on. Di ba dapat lumamig na yon? If sensor is broken, where can this be bought?
I had the A/T oil changed last June 2003 (Mobil Dextron II) but i did not have the filter cleaned (di marunong yung shop eh). Should i change again ? Whats a good shop? (Besides CASA!);)
If the A/T is overheating , what could be the cause? Oil Cooler? or Clutch Disc needs replacement? (Pero di pa ko sliding clutch eh)
