Results 31 to 40 of 40
- 99
July 8th, 2008 04:54 PM #31pwede po ba ang Fully Synthetic Oil sa Nissan Sentra LEC 94 model? thanks
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 20th, 2008 11:27 AM #32yeah why not? synthetic oil can be used on all vehicles. just follow the viscosity rating needed.
July 20th, 2008 07:08 PM #33
July 22nd, 2008 10:13 AM #34
July 22nd, 2008 12:32 PM #35
got a gas fed toyota engine... comes with operating manual that says oil change at every 10k mileage & 5k for diesel engine. but I go with the casa standard change oil PMS at every 5k. bakit meron yatang contradiction dito.
pero may note na "if car is driven in rough and dusty condition Oil periodic change should be every 5K". siguro naman this dont apply sa road condition na ruta ko. ano nga ba ang tama???
July 22nd, 2008 10:13 PM #36
thats no problem, as long as you use the recommended type of oil. (eg. dot 3 for brake fluid)
it really depends on your usage... yung mineral and semi synthetic, 5k kms and 7.5kms max respectively or 6 months. sa fully synthetic naman 10k kms max or 1 year.
kung more than 10k ka a year sa usage, then ok yung full synthetic.
well, eto yung follow ko sa change oil rituals ko.
Tsikot Member Rank 4
- Jun 2006
- 2,605
July 23rd, 2008 08:59 AM #37Like Archie said, ok lang as long as you use the correct rating. Although, some premium brands like Motul and RP are better than more common brands. It really depends on your budget and preference.
For ATF use Dexron III if its what the manual specifies. If manual says use Dexron II, you can use Dexron III. They say that synthetic ATF is better than ordinary ATF. Cant say for sure as I've never used synthetic ATF.
Power steering usually uses ATF.
Brake fluid, most common is dot 3. Some cars use DOT 4. Not sure but I think you can use DOT 4 in cars that require DOT 3. There is DOT 5 which is NOT compatible to DOT 3 and 4.
July 23rd, 2008 09:34 AM #38
July 23rd, 2008 05:04 PM #39
alam ko pag nag shift ka from DOT 3 to DOT 4 dapat drain and flush container then place the DOT 4. (correct me if im wrong na lang mga gurus)
- Nov 2003
- 3,849
July 27th, 2008 10:45 AM #40the only way you'll know if a specific fluid is ok for your car is if you check your manual. it should be in the glove compartment and it will have all the info you need for compatibility, viscosity, etc.
Suzuki JIMNY [merged threads]
