Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
    Nov 2003
    #21
    you can't bring your own oil to casa ba? alam ko some allow you to.
    Sep 2006
    #22
    Tama ba ang sinasabi nito regarding frequency sa pag change oil ng synthetic oil at regarding doon sa oil leak?
    [SIZE=5]Synthetic Oil Explained[/SIZE]
    [SIZE=2]Whether it's evil stuff or good stuff depends on who you talk to. And a lot of what you hear from backyard mechanics is rumor and myth. Myth # 1 is the claim that you don't have to change Synthetic oil as often as regular motor oil. Remember when Mobil 1 said you could go 25,000 miles between oil changes with synthetic oil? Notice they haven't said that for a good number of years? Keep that thought on the back burner for now... Myth #2 is that synthetic oil causes oil leaks. In this article I'm going to try to dispell these myths for you with the cold hard facts about the differences and similarities between dino vs. synthetic oil.[/SIZE]
    [SIZE=2]Let's talk first about what "dino" oil is (Dino is short for Dinosaur, which is when it started forming). Dino oil is created from something called "Base Stock". Base stock what the oil companies get after they have processed the crude oil that comes from the ground. From there, additives are combined with the Base Stock, to create our motor oil. There are 7 main additives which include anti-foaming agents, anti-corrosion, etc, etc. At the molecular level, dino oil contains molecules of varying sizes. Imagine the floor of a gymnasium covered with basketballs, baseballs, volleyballs, and beach balls. Now imagine that all those different size "balls" are moving around, flowing past the floor. Every time a ball surface contacts the floor surface, the ball absorbs heat from the floor. That is how oil removes heat from your engine components, from surface to surface contact.[/SIZE]
    [SIZE=2]Now imagine the same gymnasium floor covered in uniformly sized golf balls. Smaller, more uniform molecules can absorb more heat from a surface, because there are more of them AND they have a larger surface to volume ratio which means they have more surface area contact. That's what synthetic oil is. A man-made "Base Stock", where all the molecules are the same size, and smaller than those in dino oil. Better heat transfer, better lubricating properties, and a lot wider temperature range without breakdown, are now obtained. [/SIZE]
    [SIZE=2]Myth #1 debunked[/SIZE]
    [SIZE=2]Oil does not break down under normal use. This is true of both dino and synth oil and is also the reason why you take oil to the Recycling Center and not the trash dump. So if oil itself doesn't ever degrade, why do we have to change it? The answer is twofold: additives and contamination. It will probably surprise you to learn that synthetic oil has all the same additives that dino oil has! The additives in oil DO break down, which is part of what necessitates oil changes. The other reason for regular oil changes is that with use, motor oil becomes contaminated (dirt, water, acids, etc). Using synthetic oil does not protect against either of these problems, which is why you CANNOT go further between oil changes when running a synthetic. You should still change your synthetic oil at the same intervals as you do with dino oil. Anyone want to guess how many claims Mobil 1 had to pay to people that were going 25,000 miles between changes?[/SIZE]
    [SIZE=2]Myth #2 debunked[/SIZE]
    [SIZE=2]Synthetic oil causing oil leaks is another commonly spread myth. The truth of the matter is that if all your engine seals and gaskets are in good condition, synthetic oil will NOT leak in your engine. The myth started because on occasion, an engine will leak with synthetic oil, but not dino oil. The reason for this is that the smaller molecules of the synthetic are able to get past very small crevices, where the larger molecules of dino oil cannot. But this does not mean that the synthetic oil has caused the leak, it simply has "discovered" an infant leak, and regardless of what oil you are running, this infant leak will eventually grow to a size that will allow dino oil to occupy and pass also. Synthetic oil has not been shown to deteriorate engine seals or gaskets. It is not some evil solvent that will break down sealant, or anything like that. Like was said earlier, it is just a man-made base stock, that is uniform and smaller in molecule size than dino oil. Nothing more, nothing less.[/SIZE]
    [SIZE=2]ADVANTAGES OF RUNNING SYNTHETIC OIL in AIRCOOLED ENGINES[/SIZE]
    [SIZE=2]So if you are asking yourself "What's the point of running synthetic oil, if you can't change it less often?" Here's your answer in a nutshell. [/SIZE]
    [SIZE=2]Since synthetic oil has better heat transfer qualities than dino oil, your internal engine temperatures will be lower. Things like bearings, especially, will not operate at as high of a temperature as a result. The wider range of temperatures that synthetic oil can withstand is well suited for the air-cooled VW engine. With head temperatures normally between 300-350 degrees, synthetic will not breakdown while lubricating the valvetrain components at the heads. The better lubricating properties of synthetic in general will lead to a longer engine life as well. On average, when synthetic oil is run in an air-cooled VW engine, head temperatures stay the same, but engine oil temps reduce by anywhere from 10 to 15 degrees. This is in engines that have all the correct cooling tin in place, and are not suffering from overheating to begin with. Important note: Do not run synthetic to fix a hot running engine. Find the real reason it's running hot, and fix it![/SIZE]
    [SIZE=2]Another benefit is that since synthetic oil is man-made, it can be tailored to suit a wider range of needs. Synthetic oil is now being made is such weights as 5w50, and 0w30, weights that are not possible to achieve with dino oils. [/SIZE]
    [SIZE=2]At Aircooled.Net we recommend that you run synthetic oils in all cases, with one exception: you should continue to run dino oil (and change it every 1k miles) if your car still has the stock oiling system.[/SIZE]
    [SIZE=2]In transmissions we can not praise synthetics enough; RUN IT, especially if you live somewhere that gets cold (under 30F/0C).[/SIZE]
    [SIZE=2]There is one thing I need to clarify though -- if you are not running an oil filter, there really is no point to using synthetic since your oil is going to become contaminated very quickly. Your engine will still benefit somewhat from it, but due to the higher cost of synthetic oil, the gain of running it before it becomes contaminated is negligible. Oil change intervals range from 1000-3000 miles in the VW engine with a strainer (not a filter). VWoM (Mexico) recommends 1k mile intervals on non-filtered engines; keep this in mind for your pride and joy! [/SIZE][SIZE=2]But on the flip side, the stock VW engine only takes 2.5 qts anyways, it's not going to break you if you do want to run synthetic![/SIZE]
    [SIZE=2]Eric Allred, Aircooled.Net Guest Writer[/SIZE]
    Source: www.aircooled.net
    Sept. 03, 2004
    #23
    ^^ makes sense....
    but i still go for the dino oil.... hehehehe.
    its cheaper and i don't want to take chances.
    i still go for the 5k interval.
    Sep 2004
    #24
    Quote Originally Posted by speedyfix View Post
    The casa I used to go to allows customers to bring their own parts and fluids, with a catch: they'll slap an additional 10% on top of the labor charge.
    Apr 2008
    #25
    I Go for Synthetic Fluids..
    If you plan to keep your Car till 200K Mileage and more..
    If you use Honda use Honda Fluids.. Same with other makers..
    The Car Manufacturers knows their own engine /specs..
    And they Spend years to Develop thier Own Fluids/Oils for it to Run Efficiently..
    Kahit mahal.. Of course Pag Original/Synthetic medyo pricey talaga..
    You get what you pay for sa Synthetic..
    Apr 2008
    #26
    Specifications
    * Exceeds API SM/CF
    * ACEA A3/B3
    what does this exactly mean?
    Question: Explain the Terms on the Oil Bottles such as API SM/CF. What exactly does API SM/CF and SL,SJ,SH,SG mean on the oil bottle?-- Don Haislip, Oak Grove, MO
    Answer: API stands for American Petroleum Institute. In this case, API sets the industry standards for passenger and commercial vehicles. These standards are recognized, and in many cases, developed in conjunction with car and lubricant manufacturers, including ExxonMobil. The letters next to API, such as SM, refer to the quality level of the motor oil. In the case of SM, it’s the highest available standard for passenger vehicle. CF is a diesel engine or commercial vehicle standard and the highest current one is CJ-4. More information is available at the API website: www.api.org.
    http://www.mobiloil.com/USA-English/...ain_Terms.aspx
    [SIZE=2]ACEA[/SIZE][SIZE=2] = Advisory Committee on Environmental Aspects[/SIZE]
    A3 = Gas (Petrol) High performance and / or extended drain
    B3 = Diesel / High performance and / or extended drain
    Basically A3/B3 is like saying API CF/SL, meaning it is suitable for use in both types of engine.
    http://forums.xpowerforums.com/archi...p/t-11247.html
    :google:
    Nov 2003
    #27
    ah, the old surcharge trick!
    Jun 2006
    #28
    parang corkage
    Nov 2003
    #29
    hehe! oo nga... grabe na minsan mga rules nila.
    #30
    pwede po ba ang Fully Synthetic Oil sa Nissan Sentra LEC 94 model? thanks
    #31
    Nov 2003
    #32
    yeah why not? synthetic oil can be used on all vehicles. just follow the viscosity rating needed.
    Jun 2007
    #33
    OT: sorry for the ot sir but just want to have a concrete asnwer from the likes, is rev x all terrain suitable for sportivo ? thank's
    #34
    Quote Originally Posted by userfriendly View Post
    ok lang as long as you get fluids with equivalent or better specs or ratings.
    Casa fluids are not necessarily the best for your car. It might be the best for their pocket.
    Ex. Toyota uses a so called "Toyota Motor Oil" thats SM rated with viscosity of 20w50. My car's manual says that you can use this oil as well as other thinner oils like 10w30 or 5w30. If i use the thinner oil, my FC may improve. However, I cant use the thinner oils cause Toyota will void my engine warranty if I dont use their "oil brand." Heck its not even their oil, I heard its actually repacked Caltex oil.
    Ic,
    my point would be (that's why it is OT) is the Tranny , Power Steering, Brake Fluids, etc....
    would it be Ok to use the aftermarket ones (lets say, MOTUL)
    #35
    got a gas fed toyota engine... comes with operating manual that says oil change at every 10k mileage & 5k for diesel engine. but I go with the casa standard change oil PMS at every 5k. bakit meron yatang contradiction dito.
    pero may note na "if car is driven in rough and dusty condition Oil periodic change should be every 5K". siguro naman this dont apply sa road condition na ruta ko. ano nga ba ang tama???
    #36
    Quote Originally Posted by mackkcam View Post
    Ic,
    thats no problem, as long as you use the recommended type of oil. (eg. dot 3 for brake fluid)
    it really depends on your usage... yung mineral and semi synthetic, 5k kms and 7.5kms max respectively or 6 months. sa fully synthetic naman 10k kms max or 1 year.
    kung more than 10k ka a year sa usage, then ok yung full synthetic.
    well, eto yung follow ko sa change oil rituals ko.
    Jun 2006
    #37
    Ic,
    Like Archie said, ok lang as long as you use the correct rating. Although, some premium brands like Motul and RP are better than more common brands. It really depends on your budget and preference.
    For ATF use Dexron III if its what the manual specifies. If manual says use Dexron II, you can use Dexron III. They say that synthetic ATF is better than ordinary ATF. Cant say for sure as I've never used synthetic ATF.
    Power steering usually uses ATF.
    Brake fluid, most common is dot 3. Some cars use DOT 4. Not sure but I think you can use DOT 4 in cars that require DOT 3. There is DOT 5 which is NOT compatible to DOT 3 and 4.
  18. #38
    Puwede yata DOT4 sa DOT3, but you need to replace fluids more often. I may be wrong though.
    Sep 2005
    #39
    alam ko pag nag shift ka from DOT 3 to DOT 4 dapat drain and flush container then place the DOT 4. (correct me if im wrong na lang mga gurus)
    Nov 2003
    #40
    the only way you'll know if a specific fluid is ok for your car is if you check your manual. it should be in the glove compartment and it will have all the info you need for compatibility, viscosity, etc.
synthetic or ordinary engine oil???
