Results 21 to 30 of 30
- May 2005
- 82
September 14th, 2005 08:36 PM #21Originally Posted by graphire
- May 2005
- 286
September 14th, 2005 08:46 PM #22Hmm... bakit hindi pa ginawa ng mga manufactureres na maging fool-proof ang mga turboed engines? Dapat kahit diretso mo pinatay yung engine naka-on pa rin yung turbo for cooldown stage.
September 15th, 2005 10:11 AM #23
Because the manufacturers will make more money when your turbo breaks down and you have to buy a new one to replace it.
September 15th, 2005 01:16 PM #24
Never rev the engine before shutting down, not only will you force unburnt fuel to accumulate in your cylinders, you'll also risk the timing belt/chain jumping off a slot due to sudden change in engine speed.
September 26th, 2005 02:21 PM #25
in my ride i didnt see anything in the manual that states i have to let the turbo cool before turning it off. unless i didnt get to see it in the manual. but anyhow. i wait around 20 seconds before shutting down. i guess thats good enough..btw..is there an indicator on the consule to check if the turbo is cooled?
September 26th, 2005 06:53 PM #26
my sequence is turn off the radio, air con then the engine. Rev the engine or idle for a few minutes, I believe is a waste of gas.
FrankDrebin GuestSeptember 26th, 2005 07:19 PM #27Originally Posted by Ungas
September 26th, 2005 10:05 PM #28
Idling a few more minutes wouldn't even hurt your wallet nor waste fuel. I'd rather waste a few more drops of fuel instead of much costlier repairs.
September 27th, 2005 06:13 PM #29Originally Posted by babymim
September 27th, 2005 11:12 PM #30
Ako, when I park i first look around kung potentially bad neighborhood, baka kasi may biglang tumutok sa akin!!! hehehe. It s become a habit. I just look around with the engine on para pag may suspicious characters na papalapit...oooops...change parking na and drive away. Ngayon pa, uso ang carnapping! BUt I usually let it idle for 2 mins. TDIC rin kc ride ko. Sa bahay no problem. opening the gate takes around that much time.
Xiaomi E-Car
