Quote Originally Posted by aejhayl17 View Post
a throttle body for a cylinder? wow! anu kaya ang boost nito? exceeds a turbocharger kaya?
It just means better air flow into the cylinders. Less problems with flow turbulence, venturi flows, etc. Also better control on the air and fuel mix flowing into the cylinders.
This was the performance solution when early single point efi systems were introduced. Some cylinders ran rich while at the same time, other cylinders ran leaner with a single point fuel injection system.
