Results 1 to 14 of 14
    guys, ask ko lang kung anung tawag sa mods na yan? it seems na parang wala ng airfilter yung intake?
    any details? hehe nacurious ako
    thanks
    You wouldn't want to drive your car everyday without an air intake filter. It would just shorten the life of the engine.
    parekoy pang razing razing lang yan.. yari ka dyan sa everyday driving. :P
    pero isa lang tawag sa mods na yan.. ASTIG! hehehe
    yun nga po sir gh. seen this "super mods" many times pero di ko pa din alam ang tawag sa kanya. anu po ba ito?
    and, no intention of slapping that kind of mods, not now hehehe
    Quote Originally Posted by kenkoyski View Post
    yup i know hehe i dont plan anything to slap it to my car. curious ako anu ang tawag sa kanya and details?
    as i can see, its worth hundreds of K's!
    Jun 2009
    ayan ba yung tinatawag na blower?
    Quote Originally Posted by aejhayl17 View Post
    Individual throttle body with fuel injection?
    Aug 2004
    That looks like fuel injected individual throttle bodies.
    The ones you probably see "all the time" are most likely dual weber carburetors with individual throttle bodies, which are cheaper and easier to find.
    a throttle body for a cylinder? wow! anu kaya ang boost nito? exceeds a turbocharger kaya?
    It just means better air flow into the cylinders. Less problems with flow turbulence, venturi flows, etc. Also better control on the air and fuel mix flowing into the cylinders.
    This was the performance solution when early single point efi systems were introduced. Some cylinders ran rich while at the same time, other cylinders ran leaner with a single point fuel injection system.
    mas advisable pa po mag turbo/super charger rather than this kind of engine mods? but it does really look cool! thanks sir gh
    Aug 2004
    Not the same category. That's like asking if a Big Mac will fill your stomach better than a small order of fries. Of course it will... but it costs a hell of a lot more.
    It really depends on your performance goals. Some people prefer all-motor setup while others want forced induction.
    For better power to money spent ratio, going for turbocharger is better.
    which is the big mac(better) and the fries sir(good)? the turbo or the throttle bodies? which is which? thanks sir
    thanks sir niky and sir gh.
super mods!
