Results 1 to 10 of 14
- Jun 2012
- 2
June 28th, 2012 12:01 PM #1Hi Guys,
Question naman po nag check ako ng oil ko so inalis ko un dip stick may mga oil na tumatalsik sa butas ng dip stick. Ano po bang problem ng sportage ko syanga pala naka idle ung makina ko ng inalis ko yung dip stick.
sira na po ba makina ko?
Thanks po in advance
Sling
Engine details:
1996 Kia Sportage 2WD
RF Diesel
Manual
June 28th, 2012 12:44 PM #2
Piston rings seriously shagged, pressurising the block. Any loss in power though?
- Jun 2012
- 2
June 28th, 2012 02:01 PM #3
June 28th, 2012 02:33 PM #6
is your air filter getting evidence of oil from the inboard side? have your pcv valve checked, cleaned or replaced. pressure in the crankcase is normal to some extent since the piston rings have gaps regardless of how new the piston rings and the cylinder bores are. if the pcv valve is clogged up or stuck closed, the crankcase pressure pushes some oil vapors to the inboard side (cleaner side) of the air filter
June 29th, 2012 01:15 PM #8
. . . . . . . . . . . . . . . . . . . ________
. . . . . . .?. . . __. . . . . . . . . . . . . . . . . . . . :`. . . ./
. . . . . . . /__.(. . .“~-,_. . . . . . . . . . . . . . ,:`. . . .. ./
. . . . . . /(_. . ”~,_. . . ..“~,_. . . . . . . . . .,:`. . . . _/
. . . .. .{.._$;_. . .”=,_. . . .“-,_. . . ,.-~-,}, .~”; /. .. .}
. . .. . .((. . .*~_. . . .”=-._. . .“;,,./`. . /” . . . ./. .. ../
. . . . . .(. ..`=-,,. . . .`. . . . . . . . . . . ..(. . . ;_,,-”
. . . . . . \`~.*-,. . . . . . . . . . . . . . . . . ..|,./.....\,__
,,_. . . . . }.>-._\. . . . . . . . . . . . . . . . . .|. . . . . . ..`=~-,
. .. `=~-,_\_. . . `\,. . . . . . . . . . . . . . . . .\
. . . . . . . . . . . . . . . . `:,, . . . . . . . . . . . . . `\. . . . . . ..__
. . . . . . . . . . . . . . . . . . . . _\. . . . . ._,-%. . . ..`\
June 29th, 2012 01:41 PM #9
Is this the normal practice to check the dipstick when the engine is idle? I thought the best way to check it is when the engine is cold and off. Too read accurately the oil level in the dipstick.
June 29th, 2012 01:55 PM #10
ang perfect way talaga dapat ang makina mo medyo uminit then turn it off then tingin dipstick dapat ang langis kumalat sa loob ng makina yun ang super accurate way
Is it true na may recall ang yaris cross hev recently regarding sunroof issue? Lol.
China cars
