Results 1 to 14 of 14
    Jun 2012
    Hi Guys,
    Question naman po nag check ako ng oil ko so inalis ko un dip stick may mga oil na tumatalsik sa butas ng dip stick. Ano po bang problem ng sportage ko syanga pala naka idle ung makina ko ng inalis ko yung dip stick.
    sira na po ba makina ko?
    Thanks po in advance
    Sling
    Engine details:
    1996 Kia Sportage 2WD
    RF Diesel
    Manual
    Piston rings seriously shagged, pressurising the block. Any loss in power though?
    Jun 2012
    Quote Originally Posted by EE100shiro View Post
    Actually sir there is no change in power or in any performance as Ive experienced.
    General or Top overhaul sya?
    Thanks,
    Sling
    Wag!! hintayin mo na lang mawala ang hatak ng makina
    Normal Lang yan Sa diesel Diba?
    Sent from my iPad using Tapatalk HD
    Feb 2009
    Quote Originally Posted by scorpionking12 View Post
    Hi Guys,
    Sling
    Engine details:
    RF Diesel
    Manual
    is your air filter getting evidence of oil from the inboard side? have your pcv valve checked, cleaned or replaced. pressure in the crankcase is normal to some extent since the piston rings have gaps regardless of how new the piston rings and the cylinder bores are. if the pcv valve is clogged up or stuck closed, the crankcase pressure pushes some oil vapors to the inboard side (cleaner side) of the air filter
    Oct 2011
    ibang ang naiisip kong squirt.
    . . . . . . . . . . . . . . . . . . . ________
    . . . . . . .?. . . __. . . . . . . . . . . . . . . . . . . . :`. . . ./
    . . . . . . . /__.(. . .“~-,_. . . . . . . . . . . . . . ,:`. . . .. ./
    . . . . . . /(_. . ”~,_. . . ..“~,_. . . . . . . . . .,:`. . . . _/
    . . . .. .{.._$;_. . .”=,_. . . .“-,_. . . ,.-~-,}, .~”; /. .. .}
    . . .. . .((. . .*~_. . . .”=-._. . .“;,,./`. . /” . . . ./. .. ../
    . . . . . .(. ..`=-,,. . . .`. . . . . . . . . . . ..(. . . ;_,,-”
    . . . . . . \`~.*-,. . . . . . . . . . . . . . . . . ..|,./.....\,__
    ,,_. . . . . }.>-._\. . . . . . . . . . . . . . . . . .|. . . . . . ..`=~-,
    . .. `=~-,_\_. . . `\,. . . . . . . . . . . . . . . . .\
    . . . . . . . . . . . . . . . . `:,, . . . . . . . . . . . . . `\. . . . . . ..__
    . . . . . . . . . . . . . . . . . . . . _\. . . . . ._,-%. . . ..`\
    Oct 2011
    Is this the normal practice to check the dipstick when the engine is idle? I thought the best way to check it is when the engine is cold and off. Too read accurately the oil level in the dipstick.
    ang perfect way talaga dapat ang makina mo medyo uminit then turn it off then tingin dipstick dapat ang langis kumalat sa loob ng makina yun ang super accurate way
    Aug 2004
    Like 1DLV/VLD1 says, it's not a good idea to check the oil while the engine is running.
    The markings on the dipstick are calibrated for cold engine readings. The engine not only has to be off. It has to have been off for at least half an hour to an hour to allow all the excess circulating oil to go back to the oil sump. If you're checking while the engine is running, half your oil will be circulating through the oil filter, through the crankcase and through the cylinder head.
Squirting Oil
