Results 1 to 10 of 12
- Oct 2011
- 21
January 21st, 2012 06:43 AM #1Good day sirs... I just got my cars.. and this is my 1st time also im newbie in fourwheels.. i was just thinking about speeding up my car.
maybe you can help me of what to do to speed it up? mga tips lng po and do i have to change anything? something like that.. it would help me a lot.. thanks for the help... ^_^
- Apr 2009
- 1,902
January 21st, 2012 07:34 AM #2For starters, search for discussions and reads here about:
Tuning up (oil/filter changes, spark plug replacements etc)
Intake-Header-Exhaust (IHE) upgrades
Apart from that, the obvious steps will be:
1. Weight reduction (driver and car alike) - does not add "speed up" figures to the engine but a lighter car (and driver) will go faster than when it is heavily stuffed with unnecessary items.
2. Proper overall maintenance (especially engine and brakes)
A piece of advice before you want to "speed up":
Make sure your brakes are in good shape. If in doubt, upgrade.
I had to learn that the hard and expensive way.
Make sure you can brake faster than your car can accelerate.
More Tsikoteers here will help you up.
Just be polite enough to ask and be willing to learn.
January 21st, 2012 10:36 AM #3
First, what car do you have?
Next, if you want to go fast, start with the driver, not the car. You might want to get some racetrack time or some race driving instruction/training. This way you can get the most out of the car you have now.
Last, start modding the car but slowly and properly. Make sure you can stop the car as well as you can make it go quicker.
January 21st, 2012 10:52 AM #4
If you can take your car to its limits right now, then that's the sign to upgrade your engine. If not, then it's a sign to upgrade your balls.
Where's the fun of modding your vehicle to go-fast when you don't have enough balls to take it to 200kph? Hehe.
I hope you get my point.
But yes, before you entertain high-speed driving make sure your brakes are trustworthy. Invest on good brakepads atleast. And have them checked by a mechanic to make sure.
- Oct 2011
- 21
January 22nd, 2012 09:48 AM #6thanks for the precaution sir's.. yes i came from a motorcycle ride.. for motorcycles i used to change my cylinder block, cam shaft, pipe, pulleys, pin and etc to have more power.. but i know it will be different when it comes to four wheels. i just want to have more horse power than it used to be. like for old model cars like i have. do i need to replace some parts to have more power?.. so i can go faster when i want to.. currently it take me to long to reach 150 kmph .. which i want to improve. so may i ask for help.? hehe thanks in advance
- Nov 2009
- 1,756
January 22nd, 2012 11:06 AM #7
January 22nd, 2012 03:56 PM #9
Take performance driving lessons first and foremost if your goal is to be fast and safe. This is worth much more than any mod you can spend on. You probably have not discovered over 50% of your car's performance capability if you've just started driving and if you got a second hand car, you have to first get it onto tip top operating condition in terms of engine, suspension and brakes before going onto engine and suspension modifications.
January 22nd, 2012 04:04 PM #10
I learned this the hard way many years ago... "power is nothing without control"; and i was just driving a stock car.
Once you've crossed out the basics, then you go onto the car itself. What car do you have? If you want something fast, then you have to start with something fast. If youre really serious, there's no need to spend time on the basic bolt ons. Take off the engine and put in something with much more gusto if you're piddling around with a econo car. Prepare your wallet. :D
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
