Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Feb 2010
    Guys what SPARK PLUGS are you using? How to know if it's time to replace it? TIA!!
    Aug 2010
    ..dun sa isang auto ko,..standard plugs (ordinary) 4 times a year ako magpalit ng spark plugs bale quarterly, kahit pwede pang linisin e, pinapalitan ko na...
    pero ngayon naka-IRIDIUM ng BOSCH na ako e, mas fuel-efficient, Long Lasting kesa sa mga ordinary plugs, maganda ang performance ng auto, medyo may kamahalan nga lang, but it's a great value for money,
    posted na sa change oil thread mu idol, and dame na din atang ganitong thread.
    eto oh, hope this help.
    http://tsikot.yehey.com/forums/showthread.php?t=28969
    BTT: for me, its 10k km, with regular linis atleas once a month. i use NGK regular plugs na nga lang, di katulad dati na plaitnum "daw"
    Feb 2005
    i have two sets of ordinary plugs, i change sets every week or two, and been doing this for over a year now and my plugs haven't failed me yet...
    Sa akin NGK double platinum gamit ko ang recomended mileage niya bago palitan ay 60,000 KM.
    Quote Originally Posted by speed unlimited View Post
    magkano double platinum ng NGK ngayon tol? yung BKR5EGP ko dati nasa P150 e, pero ordinary platinum lang ata yun.
    saan ka nga pala kumukuha? kase yung mga auto supply sa valenzuela di n nagcarry ng NGK platinum e.
    sorry OT
    Oct 2007
    Quote Originally Posted by PSI View Post
    I think spark plugs should last 20,000 miles on controlled tests
    to be permitted for manufacture.
    Quote Originally Posted by mark_t View Post
    base sa mga nabasa ko dati,
    regular plugs should last at least 20k km
    platinum should last at least 40k-60k km
    iridrium maximum of 100k km
    parang ganyan, di ko na maalala kung saan ko nabasa. dito din sa tsikot yun e
    Oct 2007
    Quote Originally Posted by aejhayl17 View Post
    [SIZE=2] For standard spark plugs, the service interval is typically every 45,000 miles. For platinum spark plugs, it is 100,000 miles.
    I checked at
    http://www.aa1car.com/library/cm1196.htm
    [/SIZE]
    Feb 2010
    nice info.... Im using BOSH SUPER four ata yun.... linis after six months... then palit every year...
    sobra naman yata yung every quarter ang palit ng spark plugs mga sir, at lalong lalo na yung tanggal at palit every week, baka sa kakagalaw mo ng mga high tension wires nyo ng madalas masira pa. ganyan na ba ka-unreliable ang mga spark plugs ngayon. yung isang kotse ko nga 11 years na 5 beses lang yata ako nagpalit hanggang ngayon maayos pa rin at puro mga ordinary plugs lang ang gamit ko
    Aug 2010
    Quote Originally Posted by izzy06 View Post
    hmmm yep,quartely nga ako magpalit pero (dati yun) i realize na magastos kaya i try iridium un nagustuhan ko naman, ngayon kahit once in an eclipse na lang magpalit ok na, kasi iridium na yung gamit ko, price worth it pangmatagalan na to....,
    Dec 2010
    Spark plugs should be replaced at regular service intervals but how do you know when to replace them when the engine is running poorly? Some indications would be, reduction in gas mileage or developing an engine miss. These two items are definitely indicators but may not always be the problem.
    Apr 2005
    Denso W20XRU every 10T kms. or once a year.
    Jun 2010
    recommended for ordinary spark plugs would be 10k or per year.
    My NGK BPR6EY (yung may letter V sa electrode) is one year old already. Okay pa naman
    Quote Originally Posted by EE100shiro View Post
    NGK BPR6EY; Pwede kaya eto sa Mazda Familia GEN2 ko?
    OT:
    My car's plugs(all 4) are showing carbon deposits since august this year.
    Already tried 4 new sets of cold & hot plugs(regular 85-100 petot each) from NGK & DENSO brands. Currently Im using BKR6E(recomended for B6 engine)
    Also did:change oil, tune-up; throttle body(TB) & distributor inspection then cleaning, including sensors & HTW timing gun set to 9 degrees(turned offed ECU using jumper wires)
    replace air filter
    replace valve cover gasket then engine wash to eliminate leaks but still under observation 1week already.
    fuel filter was replaced 5mos ago includes opening of crank case for oil pump strainer cleaning
    Compression test was: 155-145-165-155
    My mechanic has advised me to do engine top off for checking & possible overhaul or replace gaskets only - I'm avoiding this inconvenience, opening the engine then discover irrelevant issues. Anyone would understand my Car is already 14yrs old & still a virgin. Ala pa nakakabiyak sa oto ko, even the transmission(manual). All-stock-original parts except for valve & oil pan cover gaskets, TB gaskets, vacuum rubber hose from TB hose to valve cover & HTW & a radiator repair.
    Just a brief history: 1-click starting sya unless battery is drained, no white blue or black smoke behind it. No Idle issues, never overheat, B6-DOHC-16V still powerful even w/full load. 1 lang nag bago, umi-itim plug tip in 1week use. Sarap pag bago plugs kasi bago tune up then after a week or so rough na manakbo, chug-chug na sya pag bumabagal andar. Then replace or linis na nman ako!
    Does anybody know a place in QC where they do FUEL & EMISSION systems check clean injectors using synthesizers & then emission test. Isang lugar lang sana para less hassle. mahirap kasi mag isolate ng issue pag iba-iba gumawa
    I would appreciate a good advice! More Power, Merry Xmas & Happy New Year Thanks....
    Feb 2010
    papaz.... ano po oto mo?
    Try visiting SpeedLab along Quezon Ave. QC (across Pegasus).
    Pumunta lang ako sa NGK banawe at may chart sila doon kung ano compatible sayo. Last week punta ako NGK banawe bibili ako NGK BPR6EY out of stock may pinakita sakin NGK iba model flat ung electrode hindi ko binili then pinakita skin DENSO hindi ko binili sabi ko Thailand made yan eh.....
SPARK PLUG: when to replace
