Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
    #21
    Quote Originally Posted by PSI View Post
    papaz.... ano po oto mo?
    FaFa PSI
    Quote Originally Posted by Animo Jackpot View Post
    NGK BPR6EY; Pwede kaya eto sa Mazda Familia GEN2 ko?
    B6-DOHC-16V still powerful even w/full load.
    FaFa Civic: Tried once sa speedlab kaso they dont have facility on site & they were to busy to assist me then. i was there 8AM!
    Try visiting SpeedLab along Quezon Ave. QC (across Pegasus).
    FaFa Shiro: I have chart of compatible NGK & DENSO plugs on my B6 engine as well as fake plugs from orig! Ive been doing my homework for 4mos already & still cant find correct solution!
    Thanks mga FaFa I think best solution right now is have my injectors cleaned. I found this topic though:
    http://tsikot.yehey.com/forums/showt...t=72927&page=3
    Kaso anlayo servitek las pinas...haays outing ine! W/in the week pag ala ako nakita maybe I'll try them
    Wish me luck
    Jun 2005
    #22
    speedlab doesnt clean injectors. they just remove the fuel rail and outsource the cleaning to precision along roces ave. injector cleaning is not cheap though. inspetion of spray pattern is ar 300 per piece minimum of 4 pcs. if cleaning is required, be prepared to shell out 2000 per injector again minimum of 4 injectors. so 8k agad.
    Feb 2010
    #23
    Quote Originally Posted by sirkosero View Post
    ouch..... how do we avoid this?
    Jan 2008
    #24
    mahal naman ng injector inspection at cleaning daig pa ata yung injector cleaning at calibration ng diesel engine..
    yung spark plug can last up to 2 years yan as long as walang abnormal sa engine.. kung brown ang kulay ng tip after 5000kms ok pa yan at ang sunog maganda pa.. kung maitim eh may tama ang engine
    #25
    clean fuel idol. aka malinis na gasolina
    replacement of fuel filter at recommended interval
    anu pa nga ba? hehe di ko alam kung tama tong pinagsasasabi ko e
    #26
    2K...wooow ganun ba kamahal sa precision
    Sa Central diesel Q.ave corner ng capitol med center only charge 330/injector X 4= 1320 petot lang. problema they don't disassemble from engine, you need to find a place to take it out then bring it to them! Kaya nga hanap ako place na all in one para di hassle!
    this is their link: http://centraldiesel.com.ph/about
    GRABE naman nagastos mo
    Believe me aejhay for 4 mos using 4sets of plugs ive tried different brand of petrol!
SPARK PLUG: when to replace
