check if your engine has a turbocharged version and if the engine family is the same. usually, the engine block and head are already ready for turbo addition. the engine will not "blow up" because of turbo overboost but will surely start knocking.if the turbocharger capacity is matched with the engine and that the pressure is not excessive, it should work fine. otherwise, you can waste your money on something you might not need afterall
