Originally Posted by
jojoR.
Sir same problem occurred on my spacewagon. It turned out that one of the gears on my servo unit was chipped off that caused it to have unstable idle, changed the damaged gear, problem solved.Try to have it checked but not sure if your servo unit is like mine that can be opened to access the gears inside. I hear that a servo unit cost as much as 15k brand new so verify if your servo unit is still serviceable, the culprit might only be a gear big as a 1 peso coin. By the way the servo kit that I bought cost 1500 then I have it serviced at Mitsu Genuine Parts here in Baguio.
