Page 5 of 5 FirstFirst 12345
Results 81 to 86 of 86
    Apr 2013
    #81
    Quote Originally Posted by gutz_3110 View Post
    sabi nung gumawa ng radiator ko, ok lang walang t-stat. but then after backreading, dapat meron. yun current temperature ko siguro 2 increments below the middle. ano ba ideal temperature? i'm getting a thermostat this weekend.
    Ganyan naman talaga normal temp reading. Kapag wala ka kasi thermostat, bababa ang temp mo kapag highway driving. And matagal cold start mo. Kapag may thermostat, steady lang temp gauge mo kapag hi-way driving. Hindi siya bababa, constant na lang siya. And mabilis lang ang cold start. Mas maganda para sa engine and a bit good in fuel efficiency.
    Posted via Tsikot Mobile App
    Oct 2009
    #82
    Wala pa ako mahanap na thermostat para sa sasakyan ko, wala naman kayang magiging problem kung naka aircon ako lagi? Wala naman effect ang walang thermostat sa operation ng aircon? Thanks.
    #83
    I can attest to the benefits of re-installing the Thermostat valve. Nung bagong bili ko yung 2nd hand na gas fed revo ko, ang tagal nyang mag warm-up. Halos lagi ring mababa yung temp nya na I believe wala sa optimal temp. Erratic din yung idling, pag malamig laging mataas ang menor, pag nangalahati na, dun pa lang magnonormalize, but it would take long enough or pag natraffic lang sya nag nonormalize. Nung pinabuksan ko, tinangggal nga o wala nga yung thermostat. I decided to have it replace by an original brand, and the results were very good. Constant na yung temp nya, hindi na erratic yung idling, plus ang laki ng itinipid sa gasolina. Mas pumino pa ang andar. Regarding sa aircon pag walang thermostat valve, I think wala namang masyadong effect yun, but you would be suffering the consequences as stated above which i believe is more a negative factor.
    Oct 2009
    #84
    Quote Originally Posted by jvnj View Post
    Yes sir ganyan din un sa akin. 10 mins na ako nagpapainit ng engine 1/4'pa din un temp, kinakabahan ako baka bigla nalang kasi huminto un fan, lagi kasing nakabukas. Medyo malakas nga sa gas lalo na pag short distance lang ang mga byahe at hindi umaabot sa kalahati ang temp.
    #85
    Quote Originally Posted by eurostyle View Post
    Sir euro, I think yung sira sa inyo is yung Thermo switch, not the thermostat valve (though mas maganda ma check-up pareho). Yung thermo switch kasi ang co-control ng radiator / condenser fan, kaya pag sira ito, lagi na lang umaandar yung fan. Other negative effects of a defective or not working thermo switch are the early failure of the auxiliary fan and alternator. Lagi kasi itong umaandar at may load kaya gastado at pwersado. Mura lang naman yung switch kesa pag nasira yung fan at alternator (maliban pa yung mas malakas sa gas at di nasa optimal temp yung makina) kaya mas makakabuting paayos nyo na.
    #86
    what is your sasakyan, sir?
Should you remover thermostat?
