Results 1 to 6 of 6
- Jan 2014
- 57
February 4th, 2014 09:09 PM #1Mga sir pa help naman.
Yung nissan exalta ko lately napansin ko parang hindi maganda yung shifting from 1st to 2nd gear, yung parang napapakadyot sya. Shift shock ba ang tawag dun? Ngayon ko lang na experience yun sa exalta ko dati naman hindi kahit cold start. Anu po kaya problem saka pwede gawin?
- Aug 2013
- 475
February 5th, 2014 06:39 AM #2possible din sir na engine support ang problema. gaano na ba katagal nung huling nag palit ka ng clutch parts?
February 5th, 2014 09:41 AM #3
Automatic Exalta?
If A/T, when did you last drain the ATF? If not in the last three years or 40,000kms, you can try having an ATF dialysis done. If your car is m/t, as mentioned above, check the supports.
- Jan 2014
- 57
February 5th, 2014 09:23 PM #5Yes A/T sya. Cge i ttry ko palitan ATF and filter. Nasa magkano po kaya un?
And maganda ba yung dialysis sa transmission? meron kasi mga auto shop na hindi daw recomended yung total flush kaya drain lang ginagawa tapos papalitan atf.
February 6th, 2014 09:39 AM #6
^ Try referring to this thread for the ATF full dialysis. With an old car, i'd go with this.
http://tsikot.com/forums/transmissio...process-79697/
Ah ok. So Wala pa Lang locally released na delicą dito. Pinapakyaw kasi Ng mga outdoor lovers...
Mitsubishi Philippines
