Results 1 to 6 of 6
    Jan 2014
    Mga sir pa help naman.
    Yung nissan exalta ko lately napansin ko parang hindi maganda yung shifting from 1st to 2nd gear, yung parang napapakadyot sya. Shift shock ba ang tawag dun? Ngayon ko lang na experience yun sa exalta ko dati naman hindi kahit cold start. Anu po kaya problem saka pwede gawin?
    Aug 2013
    possible din sir na engine support ang problema. gaano na ba katagal nung huling nag palit ka ng clutch parts?
    Automatic Exalta?
    If A/T, when did you last drain the ATF? If not in the last three years or 40,000kms, you can try having an ATF dialysis done. If your car is m/t, as mentioned above, check the supports.
    Quote Originally Posted by ambasad0r View Post
    Try changing the ATF and filter.
    Jan 2014
    Yes A/T sya. Cge i ttry ko palitan ATF and filter. Nasa magkano po kaya un?
    And maganda ba yung dialysis sa transmission? meron kasi mga auto shop na hindi daw recomended yung total flush kaya drain lang ginagawa tapos papalitan atf.
    ^ Try referring to this thread for the ATF full dialysis. With an old car, i'd go with this.
    http://tsikot.com/forums/transmissio...process-79697/
Shift Shock?
