Results 1 to 10 of 16
September 14th, 2016 05:51 PM #1
Hi! I would like to seek your professional opinion guys regarding those oils? Which do you think is better in terms of Engine Parts protection? By the way I'm changing engine oil every year regardless of the KMs I run when using FS Oil(AVG. 7,500KMS/Yearly) Both oils po kase almost on the same price tag kaya I'm choosing between the two.Or if you can suggest any other good oil to use? Plus which engine flush I should use? Ngayon kase na overdue na ako sa oil change hehe - Motul Clean Engine or Liqui Moly Flush? Some folks says Motul is more okay since it is oil based engine flush? Thanks!
Car: 2011 Nissan Grand Livina (34,XXX KMs)
Sent from my SHT22 using Tapatalk
September 14th, 2016 06:20 PM #2
I prefer shell ultra. The hps should also work.
Both flushes are petroleum distillates - kerosene. Both gentle imo. Just follow correct amount to be used. Dont exceed idling time.
September 14th, 2016 08:30 PM #3
Dont use engine flush as it does not lubricate the engine parts while idling. I go to GY servitek to change oil in my mitsu and they use compressed air to flush the remaining small amount of used oil.
Sent from my MyPhone MY36 using Tapatalk
September 14th, 2016 09:08 PM #5
September 14th, 2016 09:29 PM #6
Goodyear servitek i believe use the correct equipment. An ordinary talyer will not, though. Think thoroughly - adding kerosene to the used oil is not good since it will dilute it to less than the recommended minimum viscosity grade of SAE 30, maybe turning into SAE 5. Malabnaw na masyado. Kerosine has no lubricating properties at all, may impuritiees pa yan pag natuyo sa mainit ng parte ng ICE.
- Aug 2015
- 862
September 14th, 2016 09:48 PM #8Isn't engine flush one of those things na hindi mo naman talaga ma po prove kung may effect ba or wala. Parang its there lang to make you feel better or something. Or placebo. Proven ba talaga ito?
September 14th, 2016 09:51 PM #9
September 14th, 2016 09:53 PM #10
Suzuki JIMNY [merged threads]
