Hi! I would like to seek your professional opinion guys regarding those oils? Which do you think is better in terms of Engine Parts protection? By the way I'm changing engine oil every year regardless of the KMs I run when using FS Oil(AVG. 7,500KMS/Yearly) Both oils po kase almost on the same price tag kaya I'm choosing between the two.Or if you can suggest any other good oil to use? Plus which engine flush I should use? Ngayon kase na overdue na ako sa oil change hehe - Motul Clean Engine or Liqui Moly Flush? Some folks says Motul is more okay since it is oil based engine flush? Thanks!
Car: 2011 Nissan Grand Livina (34,XXX KMs)
Sent from my SHT22 using Tapatalk
