Results 1 to 10 of 12
March 5th, 2004 12:16 AM #1
I previously used this oil in both my Strada and Trooper. Lo and Behold it did not live up to it's expectations. This oil is rated API CI-4/SL, ACEA E5, Global DHD-1, SAE 15W-40. Within 2.5k kms of use from a full oil dipstick it results dismally to an almost low to dry dipstick. This means it has very poor thermal stability. The verdict: Ditch the said oil at balik sa trusted Delo Gold Multigrade. :drool:
March 5th, 2004 03:23 PM #3
salamat sa tip
magkano multigrade? delo gold monograde kasi gamit ko. 320 per gallon lang.
March 5th, 2004 04:33 PM #4
alin mas ok? delo gold multigrade or shell helix diesel?
roydok, in your opinion which performed much better on the strada?
- Aug 2003
- 9,720
March 5th, 2004 05:50 PM #6how would you know that your oil has broken down dahil sa init, aside from ung pagbabawas?
March 5th, 2004 10:16 PM #7
i used castrol dati...ditched it..mausok pa...tried caltex..ok lang...
SHELL helix (or is it remula x!?!ung black...)ang hiyang sa safari ko talaga....
siguro kilalanin niyo mga sasakyan niyo kung ano ang hiyang na oil.
March 5th, 2004 10:20 PM #8
Rimula din ang gamit ko.
Mausok minsan pero pasado naman sa test.
March 6th, 2004 03:08 AM #9Originally posted by badkuk
Mayroon na nga palang bagong Mobil Delvac MX 15W-40 na rated API CI-4. Susubukan namin ito next time. We also tried the Citgo Supergard 500 (CI-4/15W-40) available sa S and R at 87 pesos per liter pero medyo malakas din sa oil consumption. Just to remind you thermal stability is only one of the characteristics that makes an oil a good. This is not to say the oils I mentioned above with large oil consumption are totally bad. But to me on my opinion still they are not good. :drool:
March 6th, 2004 03:15 AM #10Originally posted by fierari
salamat sa tip
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
