Results 11 to 17 of 17
December 11th, 2006 07:09 AM #11
- Nov 2003
- 71
December 11th, 2006 03:29 PM #13Your SUV does not have a "redline marker", same with my truck but they supposedly have engine rev and vehicle speed limiters programmed in their ecu's. This is supposedly set at the factory so that if your suv is stock you cannot over-rev your engine or get past the vehicle's set maximum speed.
What your guzzler? Try doing as search for rev limiter for your suv>
December 11th, 2006 03:43 PM #14
December 13th, 2006 01:34 AM #16
there are two ways of squeezing more power out of a piston engine: a) increasing displacement; b) increasing revs. Both result in cramming more fuel and air into the cylinder over a given period of time (i.e., a 4-liter engine revving at 1 rpm = a 2.0-liter engine at 2 rpm).
a large-displacement engine will usually have a low redline because of all that mass, but will produce gonzo torque at low rpm. it will also consume gonzo amounts of fuel in general. on the other hand, a low-displacement engine designed to rev to make power offers the "best of both worlds" in a sense, in that it will be capable of making good power if you want it to by revving it high and running it at high rpm... while it will sip fuel like any small-displacement engine if you keep the rpm low (although it will be slow and gutless at low rpm, relatively)
In a nutshell, not all engines have power and torque peaks at 5000-6000 rpm. Some high-revving engines like certain Honda and Toyota engines that are 2.0 liters or lower make their peak power beyond 7,000 rpm.
Between a large-displacement torquer and a small-displacement screamer though, i'll take the torquer. It will be much more comfortable and effortless to drive fast.
December 13th, 2006 12:50 PM #17
Gas engines that rev high to get optimum power (HP) need the high RPM because when you're at speed, and the gearing matches high RPM, then you get the most at that speed to optimize performance and supposedly "win".
The only reason to put power at low RPM is when you're in a drag race when you're stopped and reach max speed from a standstill.
On a diesel, however, you need to know where the maximum torque is kasi that's where the advantage is. Diesel engines get the most torque at low RPM because the diesel combustion cycle is slower, and diesel fuel cannot combust faster than gasoline, hence the powerband at lower RPM. When you have a high revving diesel, smoke results in unburnt fuel.
Gas engines do not usually have high torque kaya they need to maximize their power to compensate for that, and usually this comes at a higher engine speed.
