Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Sep 2013
    mga sir ask ko lang po…nagffluctuate yung rpm ko pag naka-stop, tapos may vibration din, tapos napapansin ko minsan lumalala nginig to the point nararamdaman ko na cya sa seat ko sumasabay pa yung surge ng vibration sa fluctuation ano kaya yun? Honda city 2002 type z manual trans. 112k mileage na nabili ko lang 2 months ago
    Feb 2009
    Quote Originally Posted by aeolian_mood View Post
    is your malfunction indicator light on or flashing? is it misfiring? what is your engine speed at idle? does this happen when the engine is cold or warmed up?
    Sep 2009
    Servo/Throttle problem.
    try mo din muna pa tune-up and palinis MAF and throttle body.
    Jul 2010
    Check na rin yun engine support baka sira na.
    Oct 2013
    pareho kami ni sir TS, same ride din tayo, yung sakin naman nag-ffluctuate lang ang RPM ko pag sa stop and go traffic, pag derecho naman ang byahe ko smooth naman, ano kaya problema pag ganun? kaka-tuneup and change oil ko lang nito last week e
    Dec 2013
    Sir try mo palitan air cleaner maybe clog na yan,den spark plug,or faulty ignition coil, check mo din fuel pump mo baka nadumi na galing sa tank or yung fuel filter mismo
    Dec 2013
    Carbon deposits in the throttle body and idle air controller will be the primary cause. Fuel will not be able to clean
    this part of the engine so it has to be manually cleaned..
    Try getting an air intake cleaning service. Suzuki in Pasig and Chevy in UN Manila will do the service for your vehicle regardless of brand
    Feb 2014
    Ts, pa update nman dito sa naging prob ng oto mo? Same prob kc tau, naayos nyo po ba? Ano po naging sira?
    Posted via Tsikot Mobile App
    Apr 2008
    patanggal mo yung throttle body for cleaning, make sure lang na dun sa marunong gumawa mo dalhin lalo na kung may mga electronic components na. this is the first thing i would do for this issue. it happened to me more than once na and this solves the issue. hth!
RPM fluctuation when on complete stop
