Page 29 of 52 FirstFirst ... 1925262728293031323339 ... LastLast
Results 561 to 580 of 1023
    Nov 2003
    #561
    thanks for passing by!
    ok naman... hehehe!
    Jan 2011
    #562
    Quote Originally Posted by jimbooze View Post
    thanks bossing. pag may time po ako, idaan ko sa inyo yung oto ko.
    hello, question po. pwede po ba yung drain oil lang then replace with royal purple? kaka replace pa lang po kasi ng oil fiter ko. nagpa 5K PM po kasi ako sa toyota pero hindi nila pinalitan yung oil since nung 1K PM ko eh nagpalagay ako ng synthetic na oil (amalie yung ginamit nila)
    worry ko po kasi kapag pinalitan ko yung filter na nilagay ng toyota eh malaman nila na nagpaservice ako ng oto aside from casa which could void my waranty
    Sir jimbooze,anong viscosity ng amalie oil ang ginamit sa iyo?kakatapos ko lang mag pa 1k pms ng vios ko yan rin ang ginamit.I googled Amalie parang ok naman na oil company.tia.
    Nov 2003
    #563
    for that milage use any 30 weight oil you can. 5w30 or 10w30 should be ok.
    Feb 2011
    #564
    hello sir speedyfix,
    could you recommend oil for my 2007 honda city M/T (1.3 IDSI). mileage is 38,000Km. Im using 15W-40 right now.
    pag RP oild na ang ilalagay, every ilang Kms ang change oil? thanks.
    Nov 2003
    #565
    use either 5w30 or 10w30. with RP replace it every 10,000 kms or once a year whatever comes first.
    Apr 2010
    #566
    Quote Originally Posted by speedyfix View Post
    ok naman... hehehe!
    huh? bagong kasal sir! Best Wishes! hehehe...
    BTT: currently at 30k.. bilis ng panahon... 5k na lang then gastos nanaman.. hahaha.. going to have royal purple ulit for my engine oil. tapos tranny and differential oils din with royal purple.
    Jul 2010
    #567
    *hisairness
    15W-50 yung ginamit nila sa altis ko. ang lapot sobra eh. dunno if its because asa break-in period pa yung oto.
    sa rp, nirecommend ni sir migs na gamitin ko yung 10W-30. ok naman engine ko.
    Nov 2003
    #568
    olidotcom, last year pa... la lang panahon to leave since the shop was in the middle of the move. thanks though!
    jimbooze, any 50 weight oil is too thick for most modern cars unless they specifically need it. most regular cars will perform well with the thinner viscosity oil lalo na kung bagong bago. most dealers don't recommend this because they don't have it even if looking at the service manual specifically recommends it.
    Jul 2010
    #569
    onga eh hindi ko talaga alam kung bakit yung 50 yung ginamit nila. next pm ko i'll ask for a thinner weight of oil.
    Nov 2003
    #570
    yeah, thickest should be a 40 weight. pero better 30
    Oct 2009
    #571
    Hi sir speedfix,
    Ano po yung recommended oil sa honda civic 2005 1.6 VTI a/t?
    Mag 30kms na sya? Punta ako this week sa shop nyo. Can i use also r.p. oil for may auto tranny?
    Thanks and more power
    Nov 2003
    #572
    kung 30k kms palang then ok to use a 10w30 oil. for your atf, RP's max atf is perfect.
    thanks!
  13. #573
    sir pang oldschool na 70'S vw beetle. 1300cc. ano po RP oil nito?
    Nov 2003
    #574
    either the 10w4 or 20w50.
    Oct 2008
    #575
    is there a RP 30 weight diesel rated oil already? TIA
    Nov 2003
    #576
    all 30 weight rp oil is sl rated only.
    #577
    hello po sir speedyfix...ano po recommended grade ng rp oil ang pwede gamitin sa 2002 honda city typez 1.3L 64th km...thanx po..
    Nov 2003
    #578
    at 60,000 kms you can still use a 10w30.
    Jun 2006
    #579
    Quote Originally Posted by vrfidel View Post
    It really depends on the car. With a Honda, 5w30 or 10w30 will be perfect.
    I have a Chevy with over 100,000 kms and I am using 5w30. No leaks car runs fine. Suspension needs lots of work but the engine is still running great. Been using RP on it for over 30,000 kms. Started using RP on it on Dec 2007.
    Nov 2003
    #580
    glad you're happy with it!
Royal Purple Oil
