Page 20 of 52 FirstFirst ... 1016171819202122232430 ... LastLast
Results 381 to 400 of 1023
    Apr 2010
    #381
    * sir migs!
    thanks for the quick reply..
    BTT: running with Royal Purple Oil from 15k change oil.. currently around 17+k.. oil color is still quite 'purple' no sludge, engine purrs like a kitten..
    changed gasoline brands from unleaded to premium.. felt more power with slight decrease of fuel consumption... (mas matipid sa gas)
    Exited for my next service... going with royal purple oil and royal purple gear & differential oils din... pag may budget pa.. pati power steering fluid isasama ko na din..
    Nov 2003
    #382
    anytime boss!
    Nov 2006
    #383
    Quote Originally Posted by speedyfix View Post
    anytime boss!
    sir how much change oil (RP 10-40) and change ATF for 97 honda city, labor and materials?
    Nov 2006
    #384
    anytime boss!
    sir how much labor and material pa-change oil (RP 10-40) and change ATF for 97 honda city?
    Nov 2003
    #385
    the oil change is 2500. the atf change is around 2400.
    Jul 2006
    #386
    hi how much change oil for nissan xtrail 2.0 liter with royal purple? Which RP oil would you recommend?
    Nov 2006
    #387
    where can we buy RP in QC or manila area?
    Nov 2003
    #388
    the xtrail will be included in the promo so 2500. you can use 10w30.
    Nov 2006
    #389
    sir, what kind of ATF do you use for the honda city, orig honda po ba? if ever, tumtanggap ba kayo eastwest credit card?
    Nov 2003
    #390
    we use RP atf. it is honda z1 rated naman.
    Feb 2010
    #391
    Sir migs in using RP oil, will my next change oil schedule be extended or same lang din na 5K? thanks!! my ride is an 05 idsi city
    Nov 2003
    #392
    you can extend to 1 year or 10k kms max with the oil. just make sure the oil is always at the correct level.
    Feb 2010
    #393
    oic...is it ok lang kahit di rin nagpapalit ng oil filter for that long period?
  14. #394
    * speedyfix: what RP oil is best for my oldschooler? it's an '88 mazda pickup truck -- gas engine. 2.6L.. manual tranny. carbureted.. 4wd (how about RP transfer case and manual tranny oil?)
    how much will it cost to change these fluids?
    thanks!
    Nov 2003
    #395
    PSI, yup no need naman to replace but if you really want to it can't do any harm naman.
    azzkkr2600, replied na to your estimate query online
    Aug 2009
    #396
    can i add royal purple for a besco oil for my isuzu trooper kasi kulang ang oil. nasa gitna sa dipstick. thanx
    Jun 2010
    #397
    Mga sir ok pabang gumamit ako ng rp oil sa civic ko kahit nasa 207k na odometer ko on ordinary oil, pero regular ang change oil every 5k. 2000 model nga pala yung civic
    Nov 2003
    #398
    baby_scar, i wouldn't mix it.
    2gud4u, yup shouldn't be a problem naman.
    Aug 2009
    #399
    ok. thanx. not recommended for mixing
    Nov 2006
    #400
    sir speedy, how much oil should i feed on my 97 honda city? TIA
Royal Purple Oil
