Depends on what your putting it on. If it's a 4m40 engine it won't work due to the M26 thread pattern.
You can use the permacool set up on any of these sizes.
3/4"-16, 13/16"-16, 1"-12, M18 x 1.5, M20 x 1.5 and M22 x 1.5. Designed to use oil filters with 3/4"-16 thread.
How every if your going to do a bypass I would recommend using a adaptor and running a 1-16" thread filter.
SINGLE Oil Filter Mount System
Adapter here.
PH3976A Oil Filter Converter~1"-16 X 3/4"-16 Bypass 2u FM | eBay
Then run either a Baldwin B7317 or the even better LF9028 (which I run) both are 5 micron bypass filters, the Baldwin is 5 microns at 50% the fleetguard is 98% at 5 microns. Fleetguard double the price. I actually have 3 of the B7317's in the Philippines which I probably won't use anytime soon because it's going to take a long time to get 25000k on my van.
