My remote bypass set up installed on my Elgrand.
The black filter is my Luberfiner XL series which is 98.9% efficient at 20 microns and 50% * 5 microns and is a full flow and a full synthetic wire backed synthetic media.
http://www.luberfiner.com/documents/...single-pgs.pdf
And the second is my Fleetguard Venturi combo filter. Basically the best spin on filter you can get for the money period. 98.9% efficient at 20 microns on the full flow and 98.9% efficient at 5 microns on the bypass section.
http://www.cumminsfiltration.com/pdf...LT36043-GB.pdf
http://www.cumminsfiltration.com/pdf...es/LT36043.pdf
I will safely be able to go around 35000klm between oil changes. I'm using Mobil Delvac 1300 super 15w40 with a bottle of zddp plus to get my zinc phosphorus levels to around 1800ppm. Engine is extreamly smooth and the oil only has a light black tint to it. The first 2 days it was still clear.
I will do a oil analysis at 10000k on the oil. Getting a sample is easy I just open up the port on the side of the filter mount.
