Results 3,581 to 3,590 of 3899
February 1st, 2014 12:40 PM #3582
BD7029
Thread: M24 x 1.5
O.D.: 3 31/32 (100.8)
Length: 4 27/32 (123.0)
BD7028
Thread: M26 x 1.5
O.D.: 4 1/4 (108.0)
Length: 5 27/32 (148.4)
- Sep 2008
- 596
February 1st, 2014 12:56 PM #3583
February 1st, 2014 03:25 PM #3584
- Jan 2008
- 172
February 3rd, 2014 10:04 PM #3585
February 4th, 2014 09:41 AM #3586
We recently changed the oil in our Grandia (2.5 D4d) and i noticed that the rubber gasket may have failed on the BT223, or the Toyota mechanic who did the last oil change miffed up the install. The filter was on for roughly a year and two months and 6,000kms (Toyota FS). There were no visible leaks in the engine bay area or where we park the car (save for some oil residue where the filter housing is) and we had to add around half a liter of oil late last year.
- Sep 2013
- 630
February 13th, 2014 03:11 AM #3587
February 15th, 2014 06:59 PM #3589
Pag uneven na ang distance ng media pleats at bended pa, as can be seen sa picture above, clogged na media, hirap na pass ang oil, baka malapot na.
Ilan kms used ang filter?
Posted via Tsikot Mobile App
- Oct 2011
- 38
February 15th, 2014 09:49 PM #35908500 kms
used with Idemitsu Extreme Touring 15W-40 DH-1 (TBN 13.2) + Liquimoly Mos2 Oil Additive
Madulas na madulas pa ang langis...ganda pa ng consistency.
Dubious B109 ito. Kasi cross ng B109 is Fleetguard LF 3433 and Vic C503. At that time bumili po ako kay Volmax, di ko alam ang cross ng ng C512 na para po sa crosswind ko na 2004 manual. Eto ibinigay sakin kasi sabi dun kasukat ng C512...
So kala ko po ok na. Ng madaan ako sa 8th st new manila...bumili ako reserba na fleetguard LF3433 kasi ng icheck ko nga po cross ng B109...LF3433 ang lumabas. Ng pagbili ko..aba...malaki masyado ang LF3433 para sa akin. Nagulat po ako. Pero pinaabot ko pa rin 8500 kms. Kasi ok na ok ADBV ni "B109". Patay agad ang oil lamp indicator. Kaso ng binuksan ko kanina....masyadong maluluwang ang paper media.
Took sample of the oil for UOA. May pang check isang tropa sa Team Isuzu Pilipinas.
Nakakadala....mag Tokio Roki Isuzu na lang ulit ako....
Nagpapalusot pa rin ata ng pekeng baldwin si V
Although I think good for 6 years naman normally ang tires, personally I will look for newer ones....
Finding the Best Tire for You
