Results 2,231 to 2,240 of 3899
- Nov 2009
- 3,507
June 10th, 2012 09:43 AM #2231For Zuk APV G16A engine, BT223 is the largest it could handle. Gasket is larger than OE but spin-on base has the same diameter so no problem.
- Nov 2009
- 3,507
June 10th, 2012 09:53 AM #2232Has anyone already tried fitting Baldwin on L300FB? I took some measurements last time and i think theres a little clearance for an upgrade. The rear AC plumbing will hit the buttom of the filter.
As per Volmax, andami daw nagtatanong ng BD28 makulit daw yung lagi tumatawag sa Montero.
June 10th, 2012 10:21 AM #2233
June 10th, 2012 10:52 AM #2234
- Nov 2009
- 3,507
June 10th, 2012 11:11 AM #2235^ Yup, same with APV. Notice the buttom of filter is about the level of the crossmember, going any longer is not recommended.
June 10th, 2012 03:49 PM #2236
Bosch OM 036 vs. BD28 (don't sweat, its an new old stock from way before the "shortage").
Bosch has no crimping and has less holes. Its also wider by a bit vs. the BD28
Bosch has bottom canister plastic shrink wrap. Both have fluted tops. BD28 slightly narrower but taller.
Bosch is made in Korea (If I'm not mistaken).
The Bosch is probably a great replacement to the VIC C306 and if I'm not mistaken its also cheaper at Php 350 a pop. Solidly built and feels heavier than the BD28. I plan to put this in the L300 delivery with 3xx,xxx kms and replace that Vic C306.
<<<<:D BD28 not for sale or trade :D>>>>
June 10th, 2012 09:42 PM #2237
June 10th, 2012 09:55 PM #2238
June 11th, 2012 09:12 AM #2239
- May 2012
- 85
June 11th, 2012 03:37 PM #2240Hi everyone! This thread proved to be some heavy reading, but it helped me understand more about oil and oil filters. Kudos!
Some questions that I have:
1. Is the BT223/ B233 also applicable for older units of Toyota Corona? Mine is a 3SF engine model.
2. Also tried looking for cross reference for a B1446 for Isuzu Xwind (4jai1), it seems that the B109 will also fit. Can anyone confirm this?Also for the Xwind, is it advisable to use the Mobile delvac mx 15w 40? Saw one at true value priced at P1184 for the one gallon
Thanks a lot!
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
