Results 1 to 10 of 3899
March 28th, 2012 10:00 AM #1
wow BG, jackpot sa W&L ah, hehe. Maganda pala din yang Luberfiner. Magkakano daw yang luberfiner LFP3307?
Fasten your seatbelt! Or else...Driven To Thrill!
March 28th, 2012 10:08 AM #2
DOc,
B161-S Oil Filter
Microlite Full-Flow Lube Spin-on
Fits:Ford, Honda, Mazda
Doc, whats the meaning of microlite?? when it comes to filters?
i'll be hording filters again this week... LOL.haha
March 28th, 2012 10:24 AM #3
Doc, my current filter is LF3644 with a 14 PSI relief setting
i wanted to try
B161-S(microlite according to site) has a 20 PSI relief setting (20mm longer than LF3644)
B199 has a 8 PSI relief setting ( 40mm longer than LF3644)
Whats your opinion Doc, ?? do i choose the lower PSI or higher PSI
March 28th, 2012 10:57 AM #4
Sagutin ko na, PSI difference should be around 6-7 difference only so pasok yung B161-S but not the other one.
Pre baka puwede na rin pasama pabili ng B7095. P600 quote sa akin ng volmax at baka taasan sayo eh hehe.
http://www.4x4wire.com/forums/printt...00&type=thread
http://tsikot.com/forums/engine-fuel...9/index60.htmlFasten your seatbelt! Or else...Driven To Thrill!
March 28th, 2012 10:44 AM #5
dvldoc, just want to ask if the ff filter are interchangeable?
B1422 vs. B7033 even though gasket is different?
JS Filters :: Application Cross Reference and Image for JS : Oil (Spin-on) : C807J
JS Filters :: Application Cross Reference and Image for JS : Oil (Spin-on) : C513J
Also B173-S vs. B201-S, gasket is also different.
baldwin b173-s, full-flow lube spin-on
baldwin b201-s, by-pass lube spin-onFasten your seatbelt! Or else...Driven To Thrill!
March 28th, 2012 10:52 AM #7
Microlite is Baldwins standard media. It is a mix between cellulose and microglass giving it a high efficiency and high flow. One of the reasons their filters are so good even in standard form and not the high efficiency ones.
The B161-S is a bit longer than the B1402 which is the standard replacement so it will give you more filter surface and longer life, I always get the biggest filter that will fit on all my vehicles.
4 baldwins should last most people at least a year unless your doing a extreme amount of driving. No reason to run them under 1200klm. Since they have more dirt holding capacity over most cellulose filters and a higher efficiency rating.
- Mar 2010
- 2
January 15th, 2019 04:50 AM #8good day! can someone kindly confirm that using this oil / oil filter combo, Mobil Delvac MX 15W40 and Baldwin B113 can be used up to 10,000 kms as OCI? Thanks. Also, is Donaldson a good fuel filter? my engine is Isuzu 4JH1-TC.
Thanks!
- May 2017
- 2,128
February 3rd, 2019 06:31 AM #10
Bat pa i-share vid niya rito kung sa tingin personally na ka-duda˛ o wala pala siyang credibility...
The Toyota Fortuner has landed (fortuner pics at...
