Results 1 to 10 of 3899
    Quote Originally Posted by zix888 View Post
    Bro papost nung cusco occ mo, thanks
    i was able to find an OCC for my FM na sa wakas haha with 15mm fittings
    Bro san ka kumuha? How much?
    sa ebay taiwan ko nahanap sir. around 1800 pesos kuha ko kasama shipping. Greddy copy lang siya hehe was looking for brand-less/generic kaso ang hirap maghanap hehe dito naman sa atin, hirap maghanap ng may 15mm na fitting. pag smaller fitting kasi baka mag back pressure yung OCC, which will cause oil leaks. i have an extra set if you're interested hehe
    Oo nga, maliit yung fittings nung Cusco sa MOA eh.
    a friend did a DIY oil catch can in his patrol. after a few weeks, leaks started to come out everywhere. they were able to trace the problem to the oil catch can. the fittings were smaller than the fittings in his valve cover. kaya there was back pressure.
    after removing the DIY OCC, the leak stopped. kaya careful in installing OCC. should be a little smaller than stock lang. cant be too small.
    Dec 2007
    One thing you check prior to installing one that you can blow through it with little to no effort then you should not have a problem.
    Dec 2007
    And on your friends rig if it's the ZD30 engine he needed to live the little restrictor in place. (edit feature of forum does not appear to be working)
    Anyways, here the piece. But if you can blow through your OIL catch can it should never cause a problem.
Remote bypass oil filtration
