Page 1 of 48 1234511 ... LastLast
Results 1 to 20 of 1853
    Dec 2007
    Not much on this here so I thought I bring it up, Pretty common practice in the states on older diesels, I run it in my Elgrand 3.2 turbo diesel when I first got it the engine use to shake a lot more than I liked so I went ahead and started using 2T oil. First thing I noticed is the engine was so much quieter and smoother after the first full tank, I got a little bump in fuel economy as well and it eliminated the harsh shut off shutter I would get when I would turn off the engine.
    Let's just get the basic question over with,
    Will it hurt my engine, NO if used as described 200:1 mix ratio. example 17L tank = about 3oz 2T.
    Will it clog my fuel filter, NO
    Will it mix with diesel, Yes
    Can you use it with Bio-diesel, Yes
    Can I just add it every other tank, or whenever I want, Yes
    What's the best 2 stroke oil to use, The cheapest is the best no synthetic.
    Do I have to get the mix exactly right, No you can be a few oz or so over without harming anything. (Brother in law dump a 8oz bottle in the Elgrand had no issues) Told him 3oz)
    Should I use this on Common Rail diesels, Yes but nothing made after 2006 (which is the 2007 model)
    Does it give you more horse power, NO
    Does it change the Cetane rating, NO
    Also added it to my friends Kia Prego which you could hear comming down the block due to engine rattle, He was also very impressed with how smooth the engine became after adding it. He's been using it since Last November and plans to keep using it.
    Also did it on the family 1999 Starex, major improvement on that thing as well it use to shake like crazy at idle, I would say about a 80% improvment after 2 months of use. So for 100P to 60P for 8oz bottle it's not a bad investment. Especially for your fuel pumps life.
    Mix ratio is 200:1 by volume of fuel not ment for 2007 Up diesels.
    Here's a study done on it
    http://rivrdog.typepad.com/files/cop...-version-3.pdf
    In two-stroke oil we get 4 different quality ratings, which are based on the JASO (Japanese Automotive Standards Org.) scale:
    JASO-FA very basic single grade SAE30 or SAE40 based 2-stroke oil (premix only)
    JASO-FB Used for most premix industrial 2-stroke engines and scooters
    JASO-FC "Low ash burn" used for separate oil injection and most outboard motors. this oil can be mineral or part synthetic
    JASO-FD This is fully synthetic 2-stroke oil for racing engines. It is not suitable for mixing with diesel
    2T oil listing and ratings. You want to use the Low ash JASO-FC
    http://wcsdistributinginc.com/WCS%20...aso%20list.pdf
    I know several other Elgrand owners running it with a nice noticle difference It would be good to hear from other older diesel owners who also run 2 Stoke oil in there fuel. My Elgrand never ran smoother and I will keep using it every tank of fuel.
    It even beats out Amsoil when it comes to improving lubercation.
    The mixture of JASO-FC compliant 2-stroke oil further reduces soot and carbon deposits. this is the main reason, why the burn free cycles of particle filters are extended when using this practice. A further benefit is the increased reliability of CRD high pressure components, such as VHP pumps and injectors
    Lets here your stories or questions.
    Sep 2008
    won't it make the engine emit more exhaust smoke?
    Dec 2007
    Quote Originally Posted by GOTCH*! View Post
    2T oil in diesel reduces soot particles produced in the internal combustion process. Most people have shown a reduction in emissions by a measurable amount. The 2-stroke oil will be absorbed by the diesel (emulsion) and grease every moving part of the high pressure pump and the injectors. Besides this, the 2-stroke oil will keep the diesel engine clean, as it burnes cleaner as the diesel itself. In other words, the 2-stroke oil has a much lower ash-content as diesel, when burned.
    My Elgrand does not smoke at all and my emissions were only 0.25 due to it's modifications. I did not get any additional smoke adding the 2t to it. The our Starex got .20 better than it did on it's last emission test and since adding the 2t I have never noticed any increased smoke, it also does not smoke at all (slightly modified as well) only blew a 0.33 down from a 0.53 so I would say it's running cleaner.
    The reason you should not use fully synthetic is the Jaso-FD compliant oil leaves a solid residue that cannot be burnt.
    Here's a good comparison of what Bosch recommends for a vehicles injections pump as far as lubrication goes.
    FULL STUDY. http://www.arb.ca.gov/fuels/gasoline...22003bosch.pdf
    Compare this to the level of extra lubrication given by the additives and average diesel fuel. If anyone has the average content of the fuel in the Philippines that would give a even better comparison. http://www.pecj.or.jp/japanese/overs..._Y_Monsada.pdf
    Tried this just last week during refilling for full tank. Used up 200ml for 90ml for 90 liters. Have not researched correct ratio yet that is why. But knowing that it burns with gasoline and it has decarbonizer (Shell 2T), I assume that it will help clean the exhaust parts. have not really checked whether it improved the engine noise. Will check next time when I refill again.
    based on my research, ratio is .8ml for every 1 liter.
    Dec 2007
    You are correct on the ratio. .8ml per liter is 200:1 or about 1 oz per gallon. Even when I was trying it with only 17L of fuel and my brother in law put in 8oz I had no issues. for a fuel tank which is 76L for me I just dump a full 8oz bottle in. It does not have to be 200:1 the minimum should be 128:1 ratio. I only added more than 8oz a few times since I normally run bio-diesel from flying V.
    Yup I also add 2T on my diesel fuel. I'm using the 1:200 ratio.
    Correct me if my interpretation is not right coz i use 200ml 2T for 40 liters of diesel fuel.
    so, 1 liter 2T: 200 liter diesel or 0.5 liter 2T : 100 liter diesel
    or 0.25liter 2T : 50 liter diesel, thus 0.2 liter 2T : 40 liter diesel
    or 200mL 2T : 40 liter diesel.
    if you use 0.8ml 2T: 1 liter diesel or 0.0008 liter 2T : 1 liter diesel or
    0.08 liter 2T : 100 liter diesel or 0.16 liter 2T : 200 liter diesel
    thus 1 liter 2T : 1250 liter diesel.
    Jun 2007
    mine is a 2008 model sir dvldoc but the 4m41 is already in existence way before 2006....Can I still use 2T for it?
    Dec 2007
    The do not use for 2007 models does not really apply to the diesels sold there unless they are very high end cars. That warning is more for US Turbo diesel trucks and high end cars like BMW and Mercedes turbo diesels I posted on here regarding this on a early post. None of the JDM diesel fall into this category or even vehicles like the Fortuners with the D4D they are not the super high pressure Common rail and high end pizo-injectors that these would effect that were designed to run on low sulfur diesel.
    The 4M41 has been around since 2000 and has not changed at all.
    http://www.mitsubishi-motors.kiev.ua...ee9409/11B.pdf
  9. #9
    so its safe for toyota's D4d's, 1st crdi's of mitsubishi and older crdi's of the korean cars here? and its not safe for the newer VGT-equipped diesels (like new sta. fe, montero/strada vgt mercs and bmws)?
    May 2009
    Tried it yesterday on my way home from my beloved province.....
    Ran 360 km for 8 hrs. started the trip at 12nn...Engine non-stop.
    Filled up 100 ml to 21 liters (P1k) diesel: no effect yet (i presume)....
    Filled up again the same amount of fuel and 2T halfway through the trip: i don't really know if it's just me or my oneness with my rig....i observed greater amounts of smoking on abrupt acceleration with a 500 kg load at the back.....or could be the general behavior of these 4d56s smokin too much.....but somehow i sensed via the pedal a decreased amount of engine rattle on the 2nd fill.....
    Stuck to Shell's regular diesel and 2T during the trip.
    Pulling power and top speed seems to be the same....
    Quote Originally Posted by miked View Post
    yup, no difference in pulling power and top speed but helps in NVH being lessened and the shut off shudder.
    Dec 2007
    Quote Originally Posted by alwayz_yummy View Post
    You can use it in the D4D and other CRD's there. The only ones this does not apply to in the Philippines like the Merc and bmw newer diesel engines. Most there are what's considered 2 generation common rail not 3rd generation which have the much higher fuel rail pressure. 3rd Gen have rail pressure of 1800bar and up and pizo electric injection nozzles.
    I will quote myself to save the trouble of retyping this.
    For the Philippines it is pretty much good for any diesel, except BMW, or Mercedes and the newer rovers (high end stuff) with extreamly high rail pressures and super advanced piezoelectric injectors. (Example these cars are making 2000bar/29000psi of fuel pressure vs a 3.0 D4D which is only 1350bar/19580psi so this could cause a problem if your thicking things up)
    Works fine on D4D engines like the Fortuner with no issues, Would probably solve a bunch of issues with the 2.5 D4D as well.
    No real testing shows it causes any issues to any vehicle, the 2007 and up thing is a recomendation ie the word (may cause harm). And since the CRDI sold there are not the super high tech ones I would not hesitate on using it.
    But if you got a non common rail diesel (Any) you should not hesitate to use it. Once you start you won't stop putting it in
    Jun 2011
    Sir meron naba nkapagtry sa crosswind?
    Mar 2004
    Ignore the troll guys, probably a reincarnation of Old Blue.
    I guess this 2t oil process is only applicable to old school diesel vehicles, not the new crdi engines?.......
    Quote Originally Posted by KCboy View Post
    Not for the high-powered CRDi talaga.
    Dec 2007
    You can use this in CRDI engines. There are no vehicle sold in the Philippines unless imported that are the higher pressure common rail system. Things like the D4D engine are still a older design and a much lower pressure injection pump. Read back in the thread I have it posted.
    Unless you have a new turbo diesel BMW or Benz then you don't have anything to worry about since the large Ford and Dodge diesels are not sold there. So for 99.9 percent of the diesels on the road in the Philippines this can be used safely.
    Apr 2005
    trying this now on an Isuzu 6HE1 engine, Power Take Off Fire truck.
    will put in 300ml shell decarbonizer 2T *33petot/200ml to complement a 60L fill-up last night.
    hope it works considering that our truck is an emergency vehicle put to demanding use almost every call..
    will update you guys on progress...
    anyway, what does FC and FD mean?
    Quote Originally Posted by CaMoTe!!! View Post
    What is means is the API rating of the 2T. Much like the CF or SL ratings for diesel and gasoline powered cars. Use only FB or Fc rated, never FD as per the data presented here. Better if you can find a cheap FC rated 2T oil sir.
    1350bar ang pressure ng Toyota D4-D.
    1800bar naman sa Hyundai 2.0 & 2.2 R-eVGT.
    Pwede kaya sa R-eVGT yan sir?
Diesel owners that add 2T oil to fuel
