Results 11 to 15 of 15
March 17th, 2008 08:51 PM #11
Yes ph15 and d15 are the same. honda sir have dohc engine while honda civic (ek/eg) are sohc engine, SOHC stands for Single Overhead Camshaft. That means that there is only one camshaft per header. Inline engines will contain one camshaft. V-type and/or flat will contain 2 camshafts. For a SOHC engine there are usually 2 valves per cylinder but there can be more with the addition of cams for each valve.
DOHC stands for Double Overhead Camshaft. Now there are 2 camshafts per header. So in an inline there are 2 camshafts because there is only one header, but there is 4 in a V-type or flat engine. These DOHC engines usually have 4 valves. One camshaft for the exhaust valves and the other for the intake valves.
Advantages to having a DOHC engine over a SOHC is that the engine has twice as many intake and exhaust valves as a SOHC motor. This makes the engine run cooler and more smoothly, quietly, and efficiently. But the downfall is that DOHC engines cost more for repairs.
check also this link, i hope it will help, http://en.wikipedia.org/wiki/Honda_Civic
March 17th, 2008 09:01 PM #12
IMO, honda sir prices are ranges from 300k-400k it depends in the condition and model of a car.. try to browse in classified section here, BTW welcome to tsikot ms. EGGIRL..
March 18th, 2008 12:35 AM #13
if your looking for qc area for performance shop then id suggest speedlab sa may quezon ave. they have almost everything you need for performance upgrade. yung forced speed medyo malayo na... sa antipolo area na yan.
then for simple mods, go full exuast and full intake muna para konteng extra push. pero dont put high tension wires na kasi wala talaga natutulong for increase hp. but if your going for the engine looks then ok yan.
March 22nd, 2008 02:33 AM #14
I suggest Forcedspeed along Kalayaan avenue. They maintain my Honda cars.
Magaling sila dun and mabait both sa the way they do business and of course the price. They regularly join racing circuits as well so they know what they are doing.
Look for sir Jeff.
what? not convinced yet?
browse the honda club and find out what everybody is talking about:
http://z3.invisionfree.com/HCP/index...howtopic=38039
March 24th, 2008 11:01 AM #15
Xiaomi E-Car
