Results 1 to 7 of 7
June 11th, 2018 02:36 PM #1
Guys,
May nag try na ba sa inyo ng mag "PCV delete" ???
How to Install a PCV Delete - YouTube
Kung meron, please share your experiences.
Thanks!
June 11th, 2018 07:45 PM #2
- Feb 2015
- 28
June 19th, 2018 10:04 AM #4Yeh it better to try improve the pcv system rather than delete it.
Some of my improvemets on my carburetted toyota 4k.
For improved idle performance (better manifold vacuum) i modified a cheap generic blue and black plastic pcv valve so that under low load high vacuum like idle, the conicla needle contacts plastic o ring instead of metal o ring. I made the pastic o ring out of an old drivers license which is completely oil resiatant.
Installed a catch can between the intake manifold line to the pcv valve, and
another one between the fresh air supply line between the rocker cover and air filter, to stop positive crank pressures along with dirt and oil mist during deceleration from being ejected into the carby or throttle body.
June 19th, 2018 10:21 AM #5
A proper oil catch-can is about the only improvement you can do to the PCV system.
June 19th, 2018 12:04 PM #6
- Feb 2015
- 28
June 20th, 2018 12:26 PM #7Well it depends on the engine. If its carburetted, then manifold suction is crucial, so improving the seal for high suction will limit the vacuum leak which the valve is designed to attempt to seal in the first place. It is supposed to only start opening and allowing the controlled leak once load is applied and/or throttle is opened but the standard design is a little primative.
EFI on the other hand is so well controlled a little vacuum leaking isnt neccesarily going to cause enough trouble for this mod to be worth it.
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to...
