Results 21 to 30 of 45
- May 2017
- 572
June 18th, 2018 11:02 AM #21very helpful thread... so when you say modern diesel engines nowadays don't need long warmup times... how about older diesel engines from the 90's?
June 18th, 2018 11:18 AM #22
June 18th, 2018 11:19 AM #23
- Nov 2009
- 3,507
June 18th, 2018 12:46 PM #24Old and new same principle of lubrication and combustion. At idling the oil pump delivers the oil from sump to the journals, galleries, no need to rev up. Some oil on top of the engine are retained after shutoff because of anti-drain-back-valve built-in the oil filter, this helps in faster lubrication on cold startups. Oil pressure in action can be seen after startup as the oil pressure indicator in the dash extinguish in less than 2 secs.
Just start the cold engine, drive slowly maintaining low RPM until you reach operating temp.
- Feb 2014
- 2,696
June 18th, 2018 03:09 PM #25
- Feb 2015
- 28
June 18th, 2018 06:05 PM #26I think what he means is dont use high rpms. And this is good avdvice. But yea u certainly dont wanna go the other extreme and change gears earlier than usual. U should drive normally, changing gears at the same rpm as u normally would, but using about 3/4 of the power you normally would, so a bit slower acceleration to the upshift point, until the engine is somewhere inside operating temp range.
Perhaps what these tossers should be saying when they sell the vehicles, is actually yo idle the engine for aminute before shutdown, as all diesels all have turbos now amd turbos need some nice cool oil flow to cool down so the hot oil doesnt sit in the stationary hot turbo and heat up to the point it breaks down.
- Feb 2015
- 631
June 18th, 2018 06:15 PM #27How low is low RPM for the usual 2.5L - 3.0L diesel engines?
Less than 2k rpm?
June 18th, 2018 06:28 PM #28
- Feb 2015
- 631
June 18th, 2018 06:36 PM #29
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
